Kipper Posted September 15, 2009 Share Posted September 15, 2009 I have a 93 Suby with 272K miles. I am trying to replace the water pump. I am having some trouble with removing the pulley off of the crank shaft. I have breaker bar and a vice grip style chain wrench and bolt will not move. Any suggestions?? Link to comment Share on other sites More sharing options...
jamal Posted September 16, 2009 Share Posted September 16, 2009 longer breaker bar. There's also the starter trick. Link to comment Share on other sites More sharing options...
Kipper Posted September 16, 2009 Author Share Posted September 16, 2009 I know, I heard a little bit about the starter trick. Is it the one where you put the breaker bar on the frame or the ground and turn the engine over?? Link to comment Share on other sites More sharing options...
Bdubs Posted September 16, 2009 Share Posted September 16, 2009 Yes. You have an automatic? If so, there is an access hole to the torque converter on top of the transmission. You can throw a big honkin screwdriver in it to prevent the crank from spinning. This is the method I use for Auto's. Link to comment Share on other sites More sharing options...
