SPEC-Bart Posted September 12, 2009 Share Posted September 12, 2009 Hi. I was looking for more info on my problem: I just got 99 OB 2.5 automatic transmission,speedometer is actig up,it works than it drops back to zero.When i stop the car and go it usualy starts but drops back down after a while and so on.When it drops my odometer and tripmeter does not work,but rpms work all time.I also have abs problem(need new pump) and did not do transsmition flush yet. if i need to replace spedometer should i get used one or new unit fron dealer? How hard is it to replace it? thanks in advance. Bart Link to comment Share on other sites More sharing options...
cman7 Posted September 13, 2009 Share Posted September 13, 2009 I would probably get a 2nd hand one. If you buy from a dealer it will be really expensive. I've never replaced one so I don't know how easy it is to replace. Good Luck Link to comment Share on other sites More sharing options...
