Hooper Posted September 11, 2009 Share Posted September 11, 2009 Can anyone advise where can locate a schematic or tell me where in the female connector the four wires that control back up and brake lights for the trunk go? Right hand side close to trunk hinge there is a four prong (actually eight but only four wires used) connector. The four wires snapped off and not enough of the wires remain to indicate where they go. 1 Brown with yellow stripe Wire 1 Black (solid) Wire 1 White with black stripe Wire 1 Black with Red stripe Wire My receptacle has 4 pins three on the right side and one on the left. Rather than just moving them around till get it right was hoping someone could let me know......thanks so much for your feedback. Subaru dealer not any help at all... in fact did not even sell replacement part! Link to comment Share on other sites More sharing options...
Hooper Posted September 11, 2009 Author Share Posted September 11, 2009 Well had to peel back the wiring for the incoming and finally found the wiring as it was patched once before and that is why was not able to ascertain which went where. this is a poor design hope Subaru fixed in in newer legacy's Link to comment Share on other sites More sharing options...
Matty2Hotty Posted November 26, 2009 Share Posted November 26, 2009 Gosh.... Same problem!!! I need some info on what wires go where! Anyone? Link to comment Share on other sites More sharing options...
LIMITED Posted November 27, 2009 Share Posted November 27, 2009 Had the same problem. Just cut the plug out on both sides. hardwired them together and crimped it. Link to comment Share on other sites More sharing options...
Matty2Hotty Posted November 28, 2009 Share Posted November 28, 2009 Nice, well I did it today and everything works great! Pretty easy fix, I was an idiot and didn't relize that both sides of the plug has same color wires. Link to comment Share on other sites More sharing options...
LIMITED Posted December 5, 2009 Share Posted December 5, 2009 glad to help Link to comment Share on other sites More sharing options...
