1astrokeit Posted September 11, 2009 Share Posted September 11, 2009 I bought oem gaskets from subaru for up pipe, minfold, crossover, and dp. My question is, I here people saying to put permatex copper high-temp silicone on each side of the gasket. Is that necessary on all the gaskets or just up pipe? Do I even need silicone on new gaskets or is this be safe kinda thing so I don't have to pull the up pip back out? Link to comment Share on other sites More sharing options...
mwiener2 Posted September 11, 2009 Share Posted September 11, 2009 OEM gaskets do NOT require any type of sealant. People like to use various products thinking they will help seal things up, but if everything is installed and aligned correctly, you shouldn't need anything. People also occasionally have sealing issues with these pipes.... if you do, I highly recommend double thick OEM style gaskets from Grimmspeed. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
atc5 Posted September 11, 2009 Share Posted September 11, 2009 you can use a high-temp copper gasket spray, but if it's a new gasket, i wouldn't bother. Use proper torque specs and you're good to go. Link to comment Share on other sites More sharing options...
1astrokeit Posted September 11, 2009 Author Share Posted September 11, 2009 ok thanks. i hear theres a torque pattern for the up pipe to turbo? any idea where i can find that? Link to comment Share on other sites More sharing options...
dschultz Posted September 12, 2009 Share Posted September 12, 2009 I don't see any order mentioned in the manual, just torque to 26lb-ft. Link to comment Share on other sites More sharing options...
mwiener2 Posted September 13, 2009 Share Posted September 13, 2009 the 'pattern' is start at the manifold to engine and work back to the turbo My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
1astrokeit Posted September 13, 2009 Author Share Posted September 13, 2009 ok. do you garuantee no leaks if i follow your instructions? lol Link to comment Share on other sites More sharing options...
mwiener2 Posted September 13, 2009 Share Posted September 13, 2009 no My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
dschultz Posted September 27, 2009 Share Posted September 27, 2009 I think this is the sequence you were looking for: http://legacygt.com/forums/showpost.php?p=361905&postcount=60 http://legacygt.com/forums/showpost.php?p=361905&postcount=61 Link to comment Share on other sites More sharing options...
