joeyjojoe Posted March 18, 2005 Share Posted March 18, 2005 i know how the climate control system works, but i've noticed that the vent air coming in is MUCH warmer than the outside air coming through the windows. i have the temp set to 65, and have tried with the system off and only the vent open, but the air feels like it's 80 even though the outside temp is in the 50s. i also know the incoming air is collected near the engine so it gets warmer in lots of cars, but my accord was never this warm. you could maybe feel a 2 degree difference in the window air and vent air. is everyone feeling this or is my turbo blowing into the cabin? Link to comment Share on other sites More sharing options...
mwiener2 Posted March 18, 2005 Share Posted March 18, 2005 I've never been in a car that could blow air the same temp as outside air without the AC on. It's picking up heat from the all the ductwork. There's a lot of it. Moved to interior My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
jaycee Posted March 18, 2005 Share Posted March 18, 2005 Yup, I agree the Leg sometimes blows too hot even with the temp all the way down. I saw a suggestion here a while back that seems to work - just put the ac on for a few seconds and then turn it back off and it seems to allow cooler air to flow. The brief blast of ac seems to "clear the pipes". Link to comment Share on other sites More sharing options...
fan42025 Posted March 18, 2005 Share Posted March 18, 2005 Yup, I agree the Leg sometimes blows too hot even with the temp all the way down. I saw a suggestion here a while back that seems to work - just put the ac on for a few seconds and then turn it back off and it seems to allow cooler air to flow. The brief blast of ac seems to "clear the pipes". Yeap, that works for me, at least for a while. Often I leave the ac on even on normal to luke warm days. Link to comment Share on other sites More sharing options...
StringFellow Posted March 18, 2005 Share Posted March 18, 2005 Another reason why I love sunroofs. I know they can be noisy from the wind at times, but they are great when fresh/cool air is needed! Link to comment Share on other sites More sharing options...
TC100 Posted March 27, 2005 Share Posted March 27, 2005 I also have noticed the hot air coming in when trying to just vent in cool outside air. Much more so then any previous cars I have owned. Link to comment Share on other sites More sharing options...
John M Posted March 27, 2005 Share Posted March 27, 2005 In all the DSMs / Stealths I've owned, it's the exact same way. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 27, 2005 Share Posted March 27, 2005 I have an answer to this question..... If you lift the hood, the air intake for the HVAC system is only visable with the hood up. So I guess it picks up a good amount of engine heat. I think theres a tiny space by the base of the driver's side wiper where it gets air from outside. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
fan42025 Posted March 27, 2005 Share Posted March 27, 2005 I have an answer to this question..... If you lift the hood, the air intake for the HVAC system is only visable with the hood up. So I guess it picks up a good amount of engine heat. I think theres a tiny space by the base of the driver's side wiper where it gets air from outside. Sounds like a bad design. Hope they fix this in future models. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 27, 2005 Share Posted March 27, 2005 Fix not likely casue it's not broken. The AC was meant to be used... My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
fan42025 Posted March 27, 2005 Share Posted March 27, 2005 Fix not likely casue it's not broken. The AC was meant to be used... Yeah, stuff the environment. Let's have the AC on even when the outside temp is cold. Link to comment Share on other sites More sharing options...
joeyjojoe Posted March 27, 2005 Author Share Posted March 27, 2005 actually i did what someone mentioned above and turned the AC on for 2 seconds ... and then the air is fine. im' wondering if there is a pressure or valving issue that the quick AC blast fixes. i'm not really bothered now that i know how to fix it. Link to comment Share on other sites More sharing options...
fan42025 Posted March 27, 2005 Share Posted March 27, 2005 actually i did what someone mentioned above and turned the AC on for 2 seconds ... and then the air is fine. im' wondering if there is a pressure or valving issue that the quick AC blast fixes. i'm not really bothered now that i know how to fix it. OK, Subaru should then do a "BMW" and put in some smarts to auto-detect this issue and fix it automatically. This is for the vast majority of drivers who don't know the "fix" and leave their AC on all the time thinking it's a permanent issue, not realizing they just need to turn on the AC for 2 secs Link to comment Share on other sites More sharing options...
melayout Posted March 27, 2005 Share Posted March 27, 2005 Sounds like a bad design. Hope they fix this in future models. YAG: Stop blaming Subaru, which instead of going with a cheap mechanical system, installed an A/C monkey that automatically learns and adapts to your temperature inputs. To resolve the issue, stop feeding the A/C monkey till it gets it right and when it dies, just go to the dealer and have it replaced under warranty with a new A/C monkey that doesn't have an attitude like the old one. P.S. YAG: Yet Another Gripe I keed I keeed Link to comment Share on other sites More sharing options...
John M Posted March 27, 2005 Share Posted March 27, 2005 Sounds like a bad design. Hope they fix this in future models. I think it's a great design. This is the first car I've owned that the cowl area didn't have a grate that gathered pinestraw, leaves, and other debris that was impossible to remove. Link to comment Share on other sites More sharing options...
mwiener2 Posted March 27, 2005 Share Posted March 27, 2005 +1 My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
melayout Posted March 27, 2005 Share Posted March 27, 2005 Actually, today I was messing around with the A/C and as you said when you set to Vent Mode, it blows hot air, right from heater core, well here is how I got it to blow cold air from outside without the A/C being turned on. All you have todo is turn the temperature knobs of both to below 70, 65 is best, and then turn Off the system, then select Vent Mode, and then it should get air from the outside without heating it up, so it doesn't pass it by the heater core. As mentioned before, the system has its quirks and all you gotta is learn em and get used to it. Mojo I keed I keeed Link to comment Share on other sites More sharing options...
fan42025 Posted March 27, 2005 Share Posted March 27, 2005 Yikes, another solution! I'll try it, thanks. Still think they better fix this in future models. Don't get this sort of problem in any other car I've used. Can be a small but significant blot on the car. But then again we rough Suby drivers can wear it, even if Subaru have (or had) ideas to compete with BMW and the like. Link to comment Share on other sites More sharing options...
scans007 Posted March 28, 2005 Share Posted March 28, 2005 Actually, today I was messing around with the A/C and as you said when you set to Vent Mode, it blows hot air, right from heater core, well here is how I got it to blow cold air from outside without the A/C being turned on. All you have todo is turn the temperature knobs of both to below 70, 65 is best, and then turn Off the system, then select Vent Mode, and then it should get air from the outside without heating it up, so it doesn't pass it by the heater core. As mentioned before, the system has its quirks and all you gotta is learn em and get used to it. Mojo ^^Yup it pretty much remembers the last temp that it was set to, so if you shut it off with the temp at 75 it's gonna let warm air through....if you set it to 68 and shut it off you will notice the air coming through will be cooler......that's just my observation, I've never had problems with it blow'n hot air on me all the time.... Link to comment Share on other sites More sharing options...
