72RSbug Posted September 7, 2009 Share Posted September 7, 2009 1996 EJ20R (TT) engine. There is a difference between the vacuum lines on my engine and what I find in the schematics for the TT engines here's the pic http://memimage.cardomain.com/ride_images/1/3378/2641/8443820227_large.jpg This line usually is attached to the 4th block with attachments in the black solenoid box (this box is unused on my engine) and the black plastic part directly to the right side of the line (on the secondary dump valve) usually has 2 attachment but mine only has 1. like seen here: http://memimage.cardomain.com/ride_images/1/3378/2641/8443820112_large.jpg So, where does the line in the above pic I took have to go...?? currently its hooked up to the solenoid box like this but have no idea if that is correct. http://memimage.cardomain.com/ride_images/1/3378/2641/8443820228_large.jpg Link to comment Share on other sites More sharing options...
72RSbug Posted September 8, 2009 Author Share Posted September 8, 2009 Turns out this line is connected correctly (found the info on another forum). If anyone's out there that need's info on these vacuum lines, mine are all hooked up finally. Link to comment Share on other sites More sharing options...
