GTSPECB STI Posted September 7, 2009 Share Posted September 7, 2009 I just recently installed a device called a ECUDataScan. It connects to your OB II port. It allows you real time monitoring and recording of numerous parameters which I have listed below. It also is a GPS (iGo8) & Google Earth, Video& MP3 player, will let you read CELS and clear them. Excellent colour LCD screen, works with canbus protocol and good for MY99 wrx onwards. It also will measure and record your 60 ft times, 4oo, 1/8 and 1/4 mile times. You can run up to nine different parameters on each dashboard display at once and you can set the colors in any color you want and the same goes for measurements in metric, imperial, etc. It has a SD card slot and comes with a 2GB card which can then be used on your computer to give you data logs in MS Excel etc. Still coming to terms with it but first impressions are. Easy to set up and use. Touch screen functions are simple and easy. Wish I had not bought Defi gauges. I will add further feedback as i progress with its use. http://www.ecudatascan.com/ Parameters List A/F Correction #1 A/F Correction #3 A/F Learning #1 A/F Learning #3 A/F Sensor #1 (AFR) A/F Sensor #1 (Lambda) A/F Sensor #1 Current A/F Sensor #1 Resistance A/F Sensor #2 (AFR) A/F Sensor #2 (Lambda) Accelerator Pedal Angle Alternator Duty Atmospheric Pressure (bar) Atmospheric Pressure (psi) Boost (bar) Boost (cm/hg kg/cm2) Boost (in/hg psi) Cold Start Injector (Air Pump) Coolant Temperature © Coolant Temperature (F) CPC Valve Duty Ratio Engine Load (Relative) Engine Speed Fuel Economy (km/l) Fuel Economy (l/100km) Fuel Economy (mpg UK) Fuel Economy (mpg US) Fuel Injector #1 Pulse Width Fuel Pump Duty Ignition Total Timing Injector Duty Cycle Intake Air Temperature © Intake Air Temperature (F) Intake OCV Current Left Intake OCV Current Right Intake OCV Duty Left Intake OCV Duty Right Intake VVT Advance Angle Left Intake VVT Advance Angle Right Learned Ignition Timing Main Accelerator Sensor Main Throttle Sensor Manifold Absolute Pressure (bar) Manifold Absolute Pressure (psi) Mass Airflow Mass Airflow Sensor Voltage Memorised Cruise Speed (kph) Memorised Cruise Speed (mph) Primary Wastegate Duty Cycle Rear O2 Sensor Roughness Monitor Cylinder #1 Roughness Monitor Cylinder #2 Roughness Monitor Cylinder #3 Roughness Monitor Cylinder #4 SCV Step Sub Accelerator Sensor Sub Throttle Sensor Throttle Motor Duty Throttle Motor Voltage Throttle Opening Angle Tumble Valve Position Sensor Left Tumble Valve Position Sensor Right Vehicle Speed (kph) Vehicle Speed (mph) Link to comment Share on other sites More sharing options...
