SUBARUCAN. Posted September 6, 2009 Share Posted September 6, 2009 So what's the deal with maintenance and costs on Subaru's, in particular the naturally aspiriated H6/H4 models. Costs from Canada would also be helpful! I want to know since I plan on buying a new Subaru and want to get my facts straight! Thanks for the help! Link to comment Share on other sites More sharing options...
PhilT Posted September 7, 2009 Share Posted September 7, 2009 Are you doing the maintenance yourself, at a local mechanics or at the dealers ? Are you buying the parts yourself online or through the dealer ? Are you using regular oil or synthetic ? So many variables. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
SUBARUCAN. Posted September 7, 2009 Author Share Posted September 7, 2009 Regular oil, everything at the dealer! Don't want to void the warranty! Link to comment Share on other sites More sharing options...
longislander1 Posted September 12, 2009 Share Posted September 12, 2009 Subaru maintenance costs are relatively low compared to other cars I've owned. An oil change at my dealer is $32 and I get a loaner, if necessary. A big killer, relatively speaking, is the annual changing of the cabin filter, which can go well over $100 with the part and installation. It's in a hard-to-reach place under the dash. A lot of dealers, including my own, ignore the factory maintenance and insist on adding unnecessary inspections, filter changes, fuel additives, etc., to drive the price up. I let my dealer get away with it because it's still not a lot of money and they treat me well. Also, while the oil change interval on the NA model is 7,500 miles, the manual and the dealers say to change it at 3,750 if the car gets heavy use. Of course, the manual defines heavy use as just about everything other than letting the car sit in the driveway. All of these tactics are, of course, designed to drive up dealer profit. If you're really tight on funds, it's best to look at the factory maintenance schedule, write down exactly what you want done and tell the dealer that you don't want anything beyond the recommended service in the manual. I finally had to do that with my old Mazda Tribute when the dealer costs started to really get out of hand (approaching the dealer maintenance charges for the Audi A6 that I owned at the time). I may have to do that at some point with my Subaru dealer if they start to get a little too greedy. Link to comment Share on other sites More sharing options...
Dust N bones Posted March 29, 2010 Share Posted March 29, 2010 What is the average cost for a timing belt replacement at the stealership for a 4th gen? Also does Subaru say to change it at 60K or 90K miles? I'm looking for an 08 or 09 Legacy Limited sedan & I just want to be sure I get all the info I can. Link to comment Share on other sites More sharing options...
shutterbc Posted April 6, 2010 Share Posted April 6, 2010 Subaru timing belts are usually done at around 90 - 105K miles. I would hazard a guess at timing belt replacement + water pump in the $600 range. Link to comment Share on other sites More sharing options...
