hifonic Posted August 19, 2009 Share Posted August 19, 2009 Am looking into getting a Turbo XS up pipe with the flex section.My question is are these known to leak? Is it safer just to go with a solid up pipe instead of having one with the flex section?Thanx for the info. Link to comment Share on other sites More sharing options...
airmike Posted August 19, 2009 Share Posted August 19, 2009 No, as long as the flanges aren't warped, you will have no issues with leaks and the flex is actually preferred for an easier installation. Link to comment Share on other sites More sharing options...
BoxerGT2.5 Posted August 19, 2009 Share Posted August 19, 2009 No get the Perrin, I hear their fitament is top notch on all their products. OBAMA......One Big Ass Mistake America! Link to comment Share on other sites More sharing options...
PineyLGT805 Posted August 19, 2009 Share Posted August 19, 2009 No get the Perrin, I hear their fitament is top notch on all their products. +2... I hear the flex leaks ... best bet is a sold it one. I have been wanting to go to stage 2 for a while and Perrin seems to make the best stuff. Plus they are super helpful on the phone if you have any questions. (Perrin Catback and Sway bars w/ endlinks) Link to comment Share on other sites More sharing options...
peteyjr Posted August 19, 2009 Share Posted August 19, 2009 He may have been joking, Perrin stuff has fitment issues all the time. Link to comment Share on other sites More sharing options...
rallyInspired Posted August 19, 2009 Share Posted August 19, 2009 ive heard of flex joints breaking over time and metal pieces being sucked into the turbo and motor destroying everything. i have the invidia and it fit perfect, quality piece Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 20, 2009 Share Posted August 20, 2009 People have had leaks with a solid pipe at the flanges, and leaks with a flex pipe at the joints. The majority of people have no problem with either. Consider this: A leaky UP can usually be fixed by adding a second or third gasket IF you have a leak. A flex leak is not really fixable IF you have one. Most people don't. Either can be installed, either won't be as easy as a DP to install though. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
PineyLGT805 Posted August 21, 2009 Share Posted August 21, 2009 I havn't heard of any problems with PERRIN till this. I have the cat back (almost 2 years now) and have had no issues with leaks. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 21, 2009 Share Posted August 21, 2009 I havn't heard of any problems with PERRIN till this. I have the cat back (almost 2 years now) and have had no issues with leaks. Catbacks are designed with a whole lot of flex in mind. They swing a bit on those 5 exhaust hangers, even if they're PU bushings. Even my obnoxiously poor fitting AutoSpeed CBE has no leaks, and I've bent it every which way. UPs are different. I have heard of at least one UP leaking from pretty much every manufacturer. GS, Cobb, Perrin, TurboXS, etc. Apples and Oranges. Odds are you will not have a leak. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
PineyLGT805 Posted August 21, 2009 Share Posted August 21, 2009 Catbacks are designed with a whole lot of flex in mind. They swing a bit on those 5 exhaust hangers, even if they're PU bushings. Even my obnoxiously poor fitting AutoSpeed CBE has no leaks, and I've bent it every which way. UPs are different. I have heard of at least one UP leaking from pretty much every manufacturer. GS, Cobb, Perrin, TurboXS, etc. Apples and Oranges. Odds are you will not have a leak. What would be the best choice then for minimal flex in a DP? I was lookin at Invidia Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 21, 2009 Share Posted August 21, 2009 The answer to that is in the steel, not the brand. You could hop on google and get the specific grade of steel in each pipe, then look up the material properties of each you find. Maybe 20 minutes total... [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted August 21, 2009 Share Posted August 21, 2009 But you could just buy a stock catless up pipe, and fitment would be perfect. With heatshields too. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
NSFW Posted August 23, 2009 Share Posted August 23, 2009 No get the Perrin, I hear their fitament is top notch on all their products. You heard that from someone who never tried to install their LGT BPV. Link to comment Share on other sites More sharing options...
