tommypenguin Posted August 21, 2009 Share Posted August 21, 2009 Avoid using newspapers or any kind of paper. A soft cloth is the way to go, but make sure it's not a synthetic material since it may be harder than the tint and cause scratches. I've have always used newspaper to clean my windows with, it doesn't leave streaks like a cloth or paper towel will and completely removes all dirt and never has scratched a window. Try it sometime before you knock it and every car I've owned has been tinted all the way around. I've never had a problem using newspaper. Link to comment Share on other sites More sharing options...
pillboy Posted August 21, 2009 Share Posted August 21, 2009 The tint in my '88 Cherokee turned purple over time. I figured it was the cheap-a$$ product Ziebart used and the dyes color-shifted over the years from UV exposure. But what do I know. It is still ugly. Link to comment Share on other sites More sharing options...
ehsnils Posted August 21, 2009 Share Posted August 21, 2009 I've have always used newspaper to clean my windows with, it doesn't leave streaks like a cloth or paper towel will and completely removes all dirt and never has scratched a window. Try it sometime before you knock it and every car I've owned has been tinted all the way around. I've never had a problem using newspaper. Doesn't the ink leave streaks then? The ink on our newspapers over here does transfer to everything - especially the fingers when reading. And some paper contains a clay as a filler, and that can work as an abrasive. Just watch out and try on a less visible spot before using newspaper. Link to comment Share on other sites More sharing options...
tommypenguin Posted August 21, 2009 Share Posted August 21, 2009 Doesn't the ink leave streaks then? The ink on our newspapers over here does transfer to everything - especially the fingers when reading. And some paper contains a clay as a filler, and that can work as an abrasive. Just watch out and try on a less visible spot before using newspaper. The ink doesn't leave streaks at least with my newspaper, I just use the Denver Post, never the ads that come in their own colored sections. I inspected my windows on my lunch for kicks since I cleaned windows over the weekend, there are no scratches on the tint film, just a mirror finish. Link to comment Share on other sites More sharing options...
MotoFanatic Posted August 22, 2009 Share Posted August 22, 2009 One tinter recommended Pledge and have used it for over 10 years without a problem. -Moto Link to comment Share on other sites More sharing options...
