loc Posted August 9, 2009 Share Posted August 9, 2009 I went to the dealership the other day because the front end was clunking pretty bad and has been for the past couple months. I come to find out that my lower control arm bushings were torn on both sides. I had replaced them about a year ago with the avo offset kit. Is this supposed to happen this quick. My car is lowered with a rallitek springs. I try to avoid potholes and bumpy roads as much as I can. What should I do next? I just looking for something that will last and be somewhat smooth. Any suggestions? Link to comment Share on other sites More sharing options...
ifbiker Posted August 10, 2009 Share Posted August 10, 2009 Take a look at this thread. http://www.legacygt.com/forums/showthread.php?t=110956 At the very least I would go with the 08/09 STi bushings all the way around the LCA. I have noticed that on the 08/09 WRX there is a spacer between the body and the bushing which is absent on a LGT. I'm wondering if this is sort of anti lift kit and would like to know the opinion of others. If it is an anti lift kit I would buy the spacer and the bracket and have it installed at the same time. Link to comment Share on other sites More sharing options...
