05lgt5spd Posted October 16, 2009 Author Share Posted October 16, 2009 bologna sandwich Link to comment Share on other sites More sharing options...
lucas569 Posted October 16, 2009 Share Posted October 16, 2009 send em my way ill install them and relay the info back! if u were closer id trade ya my black leather seats in a heartbeat! Link to comment Share on other sites More sharing options...
05lgt5spd Posted October 20, 2009 Author Share Posted October 20, 2009 I might just attempt this, I am having a hard time selling them at this price, I feel like Im giving them away! Link to comment Share on other sites More sharing options...
05lgt5spd Posted October 20, 2009 Author Share Posted October 20, 2009 update, the 06+ uses an airbag bladder plumbed to a pressure switch to sense the weight....simple. The 05's use a sensor on each corner to tell the weight. If I had both seats sitting next to eachother Im sure I could figure it out. Might be easier to swap the lower section with a power 05 style seat, as mentioned before. Look slike they can be had for $150 or so at a wrecking yard. I do have the complete 07 wiring harness, but Id rather not go down that road Link to comment Share on other sites More sharing options...
lucas569 Posted October 20, 2009 Share Posted October 20, 2009 update, the 06+ uses an airbag bladder plumbed to a pressure switch to sense the weight....simple. The 05's use a sensor on each corner to tell the weight. If I had both seats sitting next to eachother Im sure I could figure it out. Might be easier to swap the lower section with a power 05 style seat, as mentioned before. Look slike they can be had for $150 or so at a wrecking yard. I do have the complete 07 wiring harness, but Id rather not go down that road from what i was told was to take the spec b's pass seat and remove the leather... remove your pass seats leather or cloth cover and replace with spec b's... no wiring needed. youll end up sacrificing your original pass seat but imo its worth it for those awesome seats. Link to comment Share on other sites More sharing options...
05lgt5spd Posted October 22, 2009 Author Share Posted October 22, 2009 so you think I can use my cloth bottom pad and put in on the 07 spec b seat bottom? Or you saying you do the upper sections too? the seat cushion designs look different on the bottoms Link to comment Share on other sites More sharing options...
lucas569 Posted October 22, 2009 Share Posted October 22, 2009 remove the spec b seat cover and put them on your current pass seat. your just switching covers... so no wiring mess needed. http://legacygt.com/forums/showthread.php?t=103465&highlight=seat+install did i show you this link? that may shed some light on it... Link to comment Share on other sites More sharing options...
05lgt5spd Posted October 22, 2009 Author Share Posted October 22, 2009 Im just weary that the covers are different shape/size than mine. that would be the easiest way though. Even though me pass side won't have power, but who cares if it makes it that much easier! Link to comment Share on other sites More sharing options...
lucas569 Posted October 22, 2009 Share Posted October 22, 2009 Im just weary that the covers are different shape/size than mine. that would be the easiest way though. Even though me pass side won't have power, but who cares if it makes it that much easier! i dont have the seats side by side but theyve always looked like the same shape to me Link to comment Share on other sites More sharing options...
lilschwikes Posted August 17, 2012 Share Posted August 17, 2012 im really disappointed that no one has yet to figure this out =[ Link to comment Share on other sites More sharing options...
