specialB Posted August 2, 2009 Share Posted August 2, 2009 So i just installed my grimmspeed flex uppipe and started the car up...pull to the top of the driveway to check and make sure all is well (thank god i did). few moments later i see smoke so i get out and my oil is spewing all over the ground. i killed the car and watch the rest of it drain out. I was feeling around and on the motor itself i feel a hole on the bottom corner of the motor where the old pipe had to pass through. I was yanking on it pretty good before but hard enough to put a hole in the crank case?? im waiting for my camera to charge so i can actually see the damage, i realllly hope its just some rubber gasket that i f**ked up. It feels like it could be a chunk of metal missing from the engine. oh no, dear lordy... ill get the picture up as soon as i can Link to comment Share on other sites More sharing options...
urfsin Posted August 2, 2009 Share Posted August 2, 2009 I don't know how you could put a hole in your case by installing an up pipe, but strange things happen sometimes. Yes, post pics ASAP. Slide It Sideways Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 anything is possible if you try hard enough. I think you would have damaged one of the power steering cooler lines of an oil feed line before putting a hole in the block. Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 it looks wayyy too clean to be a break. can someone please tell me what goes here... http://i3.photobucket.com/albums/y89/Max00racer/LGT/CIMG4896.jpg Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 thats from the back right side of the motor looking forwards. Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 You popped out the cam plug, no disaster you just need to pull the valve cover to fix it. Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 Your oil looks milky. Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2009 Share Posted August 2, 2009 I read this happens quite a bit when people get medievel on the uppipe. You ripped out half moon seal that seals the space between head and rocker cover. The cover needs to come off, and the seal replaced. If you forced the seal inside and it got chewed by the cams, then you're in far more serious trouble. Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 He only went to the end of the driveway , he should be ok. Link to comment Share on other sites More sharing options...
qikslvr Posted August 2, 2009 Share Posted August 2, 2009 That is the cam seal/gasket. It fairly common for people who don't know the proper procedure(take nut off passenger side motor mount and jack up the engine or just pull the turbo off and go from the top) to hit it and rip that gasket out. The only fix is to take it in and have the valvecover/cam gasket replaced. Good Luck. Looks like many others replied while I was typing... Let's kick this pig! Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 Jacking the motor is much less work though. Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 yea idk why i didnt take the mount off to begin with, i was wrestling that thing for a good twenty minutes before i decided to just jack the damn motor up and it came out like 1 2 3. What a sigh of relief i thought i blasted a hole in the side of my motor i was about to have a heart attack haha. but yea i mearly backed up maybe fifteen feet out of the garage and got out and saw oil pouring. didnt even start coming out until i was done backing the car up. im soooo happy i didnt go and take it for a test run right away. a seized motor is about 45690843634986456 times worse than a seal. how much of a bitch is it to remove the valve cover?? its only a rubber seal right? so hopefully hes just hangin out down there Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2009 Share Posted August 2, 2009 He only went to the end of the driveway , he should be ok. Enough if the cam seal was chewed by the cams. The bits can be in the journal, oil passages, etc. Also, jacking up the motor for up install is completely unnecessary. The up can be removed without doing that and without damaging anything. Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 Your oil looks milky. it wasnt milky all over the driveway, just brown. fudge i wish i could get to the damn thing without having to take off the valve cover Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 Enough if the cam seal was chewed by the cams. The bits can be in the journal, oil passages, etc. Also, jacking up the motor for up install is completely unnecessary. The up can be removed without doing that and without damaging anything.[/quote./] It would wind up in the pan and get caught by the oil pump pick-up screen if anything. I can't see that pipe coming out like you say on our cars, I done at least 15 or 20 installs and no way does that thing just slide out of there, at least the OE one won't. Jack the motor and avoid poping your cam plugs . Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 how long does it take to pop the valve cover off, it looks tight in there/can you reuse those gaskets?? Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2009 Share Posted August 2, 2009 It would wind up in the pan and get caught by the oil pump pick-up screen if anything. If he is lucky. If it blocks an oil passage it may restrict oil flow somewhere. It's still mystery to this day to me what blocked cam journal on my motor causing it to sieze up. I can't see that pipe coming out like you say on our cars, I done at least 15 or 20 installs and no way does that thing just slide out of there, at least the OE one won't. I removed just one. It DOES come out without hitting anything. You need to improve your technique... Link to comment Share on other sites More sharing options...
GTTuner Posted August 2, 2009 Share Posted August 2, 2009 If he is lucky. If it blocks an oil passage it may restrict oil flow somewhere. It's still mystery to this day to me what blocked cam journal on my motor causing it to sieze up. I removed just one. It DOES come out without hitting anything. You need to improve your technique... Only way it will come out without hitting anything IME is if your removing the pass side manifold and pulling the EGT probe while the pipe is still in the car. Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 got the cover off and no signs of it yet...not even bits and pieces. maybe it fell out. still searchin Link to comment Share on other sites More sharing options...
specialB Posted August 2, 2009 Author Share Posted August 2, 2009 got er, fully in tact. how should it go back in? it need silicone? Link to comment Share on other sites More sharing options...
rurouni_x Posted August 2, 2009 Share Posted August 2, 2009 yeah you will need a tube of silicone to seal it back up, is it still in good shape a new one is like 2$ Link to comment Share on other sites More sharing options...
urfsin Posted August 2, 2009 Share Posted August 2, 2009 It looks like a little duct tape will fix you right up!! Slide It Sideways Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2009 Share Posted August 2, 2009 Only way it will come out without hitting anything IME is if your removing the pass side manifold and pulling the EGT probe while the pipe is still in the car. Well, yes and no. I removed the manifold but didn't remove the probe. Link to comment Share on other sites More sharing options...
PhilT Posted August 2, 2009 Share Posted August 2, 2009 Only way it will come out without hitting anything IME is if your removing the pass side manifold and pulling the EGT probe while the pipe is still in the car. This is the easiest way to do it, no jacking of motor is required. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Guest Posted August 2, 2009 Share Posted August 2, 2009 got er, fully in tact. how should it go back in? it need silicone? You should use new gaskets and you need sealant. I recommend Permatex Right Stuff. Regular RTV silicone is pretty crappy stuff, unless you get Fuji bond, etc. Link to comment Share on other sites More sharing options...
