jadakiss Posted July 31, 2009 Share Posted July 31, 2009 Hey guys, Recently changed ATF in my '06 LGT using the iterative drain and fill approach. The fluid to start with was kinda brown and upon doin three drain and fills as recommended in an iterative manner, my tranny fluid is still light brown..almost translucent. Why is this? I was really thinking that since i removed the majority of fluid it wud at least be kinda pink-ish? Is this a sign that the clutch has burnt or sumthing of the sort? The fluid doesn't smell full blown burnt, jus slightly burnt and it doesnt have any filings etc Should i be concered? thanks guys! Link to comment Share on other sites More sharing options...
Darkness of Death Posted August 1, 2009 Share Posted August 1, 2009 ATF should be reddish.. maybe you need a flush? how much mileage do you have on the car? Link to comment Share on other sites More sharing options...
jadakiss Posted August 1, 2009 Author Share Posted August 1, 2009 about 18K on the car so far. I don't think a flush is safe really..well from what i've read. The manufacturer doesn't recommend it as well. Link to comment Share on other sites More sharing options...
fishbone Posted August 5, 2009 Share Posted August 5, 2009 Flush should be safe and the manufacturer allows for it when it's called for (meaning they don't recommend that you do it at every oil change). I personally would, it sounds like the ATF is pretty spent. You wanna get that crap out before it starts really burning and sludging and forming deposits because THEN a flush will REALLY become unsafe. My tranny has 73K on it and I wouldn't flinch having it flushed. Link to comment Share on other sites More sharing options...
fishbone Posted August 5, 2009 Share Posted August 5, 2009 I just realized that I may have gone through the same thing you did upon my first drain. See this thread of mine. Is this what you got going on? http://legacygt.com/forums/showthread.php?t=91087 Link to comment Share on other sites More sharing options...
jadakiss Posted August 6, 2009 Author Share Posted August 6, 2009 Fishbone its real cool to have u comment on my thread..i really appreciate ur advice...ive read alot of ur posts n im always impressive thanks bro! Link to comment Share on other sites More sharing options...
jadakiss Posted August 6, 2009 Author Share Posted August 6, 2009 jus checked ur link..mu fluid is exactly like that..did the blot test next to some fresh ATF HP and same result....FLUSH FTW hehe thanks Link to comment Share on other sites More sharing options...
fishbone Posted August 6, 2009 Share Posted August 6, 2009 Do a flush, but make SURE you use OEM tranny fluid. the 5-speed automatic does NOT take Dexron III stuff. Use OEM Idemitsu fluid that comes in silver plastic quart bottles (NOT white, that stuff is for the 4-speed automatic and sometimes dealers screw up). Not using OEM is gambling with it and besides, it's top quality stuff anyways. Your dealer will be able to do the flush, if you go to another shop their flushing machine may actually require as much as 16 quarts to do a full flush since 99.9% will not readily have a machine stocked with Idemitsu ATF. Link to comment Share on other sites More sharing options...
jadakiss Posted August 6, 2009 Author Share Posted August 6, 2009 OK no problem bro ^^. Will do. Link to comment Share on other sites More sharing options...
ole whore Posted August 7, 2009 Share Posted August 7, 2009 told you so ...... Link to comment Share on other sites More sharing options...
jadakiss Posted August 8, 2009 Author Share Posted August 8, 2009 lol yes u did ^^ Link to comment Share on other sites More sharing options...
