scoobiedude Posted July 28, 2009 Share Posted July 28, 2009 first logs on stage 1. 3rd gear WOT.datalog3.csv Link to comment Share on other sites More sharing options...
testes1010 Posted July 28, 2009 Share Posted July 28, 2009 looks nice & conservative. Link to comment Share on other sites More sharing options...
scoobiedude Posted July 28, 2009 Author Share Posted July 28, 2009 thanks. just want to be sure there is no knock or detetation going on. also what parameters should I be logging. was it enough or to much? anybody else's opinion? Link to comment Share on other sites More sharing options...
iNVAR Posted July 29, 2009 Share Posted July 29, 2009 interesting. what map are you using, and what are you using to log? just curious about the DA of 1 all the way through Link to comment Share on other sites More sharing options...
scoobiedude Posted July 30, 2009 Author Share Posted July 30, 2009 Cobb OTS stage 1 91 octane. using AP to log. Link to comment Share on other sites More sharing options...
iNVAR Posted July 30, 2009 Share Posted July 30, 2009 Hrm.... that doesn't look right to me then. Someone else jump in here? You should be seeing more than 1 degree of dynamic advance throughout the entire run. here's my own log from the same map you're using : http://www.legacygt.com/forums/attachment.php?attachmentid=70899&d=1248272281 you can look at the knock correction advance column, which is equal to your dynamic advance column. (it's actually not. KCA includes adding knock correction in there, but since i'm not getting knock, it's fine for our purposes. i didn't log the equivalent of DA in RR, oops) Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 30, 2009 Share Posted July 30, 2009 Hrm.... that doesn't look right to me then. Someone else jump in here? You should be seeing more than 1 degree of dynamic advance throughout the entire run. here's my own log from the same map you're using : http://www.legacygt.com/forums/attachment.php?attachmentid=70899&d=1248272281 you can look at the knock correction advance column, which is equal to your dynamic advance column. (it's actually not. KCA includes adding knock correction in there, but since i'm not getting knock, it's fine for our purposes. i didn't log the equivalent of DA in RR, oops) The DA column is actually the Dynamic Advance Multiplier column, the highest it can be is 1.0, and that is what you want. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
iNVAR Posted July 30, 2009 Share Posted July 30, 2009 Ohhhhh, ok, learn something new everyday. BTW, not fair. The AP doesn't log knock of any sort of the 05 LGT. Link to comment Share on other sites More sharing options...
