RJS5689 Posted July 25, 2009 Share Posted July 25, 2009 I'm looking to pick up a Greddy Evo 2 Catback exhaust. What is required for me to mount it up to the stock downpipe? Link to comment Share on other sites More sharing options...
Darkness of Death Posted July 25, 2009 Share Posted July 25, 2009 maybe just a flange adapter. Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 26, 2009 Share Posted July 26, 2009 Nothing. Greddy uses the donut gasket just like the stock midpipe does. Link to comment Share on other sites More sharing options...
vduber Posted July 27, 2009 Share Posted July 27, 2009 yepp yepp my vw bud it bolts upto stock dp although i had some problems with bolting it up cause fredbeans sent me new oem bolts so i tried using them instead of the 2 greddy bolts. Next time i put her up on the lift im going to swap out the bolts and see if that works correctly, currently the springs are completely compressed and I only have a few turns on each nut. Its my fault though I should have just used greddys hardware but you live n learn! Link to comment Share on other sites More sharing options...
RJS5689 Posted July 29, 2009 Author Share Posted July 29, 2009 Sounds good. Is there any exhaust leak though? From going from a 2.5"DP to the 3" mid pipe. Link to comment Share on other sites More sharing options...
scoobydoobie Posted July 29, 2009 Share Posted July 29, 2009 Sounds good. Is there any exhaust leak though? From going from a 2.5"DP to the 3" mid pipe. The Greddy at the flange is 2.5" to mate to the donut gasket (like cobb, borla, spt, magnaflow, etc.) then becomes 3" Link to comment Share on other sites More sharing options...
RJS5689 Posted July 29, 2009 Author Share Posted July 29, 2009 The Greddy at the flange is 2.5" to mate to the donut gasket (like cobb, borla, spt, magnaflow, etc.) then becomes 3" That's the info I was looking for! Thanks for the help. Link to comment Share on other sites More sharing options...
vduber Posted July 29, 2009 Share Posted July 29, 2009 Sorry im useless Link to comment Share on other sites More sharing options...
Woodstock Posted August 1, 2009 Share Posted August 1, 2009 That's the info I was looking for! Thanks for the help. I just purchased a greddy evo 2! YAY! But, it doesn't come with gaskets. I'm not sure which one to get since there are many options, and i haven't seen it personally. I have a invidia DP 3". I wanted to order the gaskets thru fred beans. Should I get a donut or a flat? What size? I "think" I need gaskets from mid to Y then, Y to mufflers. Thanks! Link to comment Share on other sites More sharing options...
vduber Posted August 1, 2009 Share Posted August 1, 2009 I believe for your dp to mid YOU need a flat gasket since there both 3" in diameter. (When you bolt up stock dp to greddy mid then you need a donut. Also fred beans sells a pack of flat gaskets for the mid to y & y to the cans. I think there is 4 flat gaskets in that pack so you should probably be covered for everything! Hope this helps. Link to comment Share on other sites More sharing options...
Woodstock Posted August 2, 2009 Share Posted August 2, 2009 I think when I bought invidia it came with flat gasket, DP to mid 3" . (will check) I will order 4 flat gaskets then. Thanks! vduber Link to comment Share on other sites More sharing options...
