357specb Posted July 25, 2009 Share Posted July 25, 2009 Hey guys. I am having problem with my driver side foglight. I installed a hid kit on them with the relay, and now it flickers when I turn it on, then just cuts off. Any idea of what the problem could be? Link to comment Share on other sites More sharing options...
Windy Road Posted July 25, 2009 Share Posted July 25, 2009 Check the fuse that is in the harness. I was driving my car behind some friends and they where saying I was having the same problem you have. Turns out the fuse melted and would loose contact over the bumps and dips in the road. New fuse and its golden. 276hp/347tq On a DynoJet Dyno Video - Had a big lean spot as you can tell in the second pull Link to comment Share on other sites More sharing options...
CRAZY KEN Posted July 25, 2009 Share Posted July 25, 2009 ...did you twist the cables or solder it? Ask the local HID light guru mr_luv!!! CRAZY KEN Link to comment Share on other sites More sharing options...
357specb Posted July 25, 2009 Author Share Posted July 25, 2009 i solder the relays Link to comment Share on other sites More sharing options...
underpowerd Posted July 25, 2009 Share Posted July 25, 2009 check that the pins are secure inside the m/f connectors Link to comment Share on other sites More sharing options...
mr_luv Posted July 25, 2009 Share Posted July 25, 2009 what they all said make sure the wires are very secure so they dont bounce around at all. Mr.350 Link to comment Share on other sites More sharing options...
357specb Posted July 26, 2009 Author Share Posted July 26, 2009 anyone local willing to help out with this problem. I'm currently at my parents and don't have any tools to remove my bumper to check the problems. I checked the pins for the m/f connectors and they seem fine. Link to comment Share on other sites More sharing options...
357specb Posted July 29, 2009 Author Share Posted July 29, 2009 so i checked the the fuse, and the connectors. Both were fine..when i try to turn it on it sounds like its struggling to power up..flickers and little then just doenst turn on. would that mean i need a new ballast? Link to comment Share on other sites More sharing options...
hyperice Posted September 18, 2009 Share Posted September 18, 2009 You need to buy an anti-flicker wiring harness. do a search and see. Link to comment Share on other sites More sharing options...
