iNVAR Posted July 22, 2009 Author Share Posted July 22, 2009 I'm going to see if I can find a ferrite core from an old cable and clamp it on the vagcom cable and see if it helps. And thanks for sending them the PM! edit: Well I'll be damned, looks like RR just fixed it sometime between last night and today. Oops! Link to comment Share on other sites More sharing options...
LittleBlueGT Posted July 22, 2009 Share Posted July 22, 2009 I also have had the weird problem, but very intermittent. (old and now new laptop) A buddy of mine with a 16 bit ECU cannot even get one clean log. Full tune of 68HTA, KSTech 73 MAF, Racer X FMIC and ID1000s................by the DataLog Mafia!!! Link to comment Share on other sites More sharing options...
vaccaroja Posted September 22, 2009 Share Posted September 22, 2009 Both maps (93 and 91) are knocking way too much...and high in the range which is not good. I think you should fill up with 94, reset the ECU and reflash the 91 map. It could be that you just got a bad batch of fuel, but the knock you are getting is dangerous. Your WOT logs should be entirely knock free, if there is any knock i would not use the tune. Just out of curiousity... have you tried VP 103. Its ok for cars with o2 sensors. Its for street cars, everything up from that like VP 116 is like jet fuel and for high hp, high boost cars. Try some VP103 or equivalent octane and log it. 13.6 @ 102 untuned FTW SmartWax - Spec Clutch - Team Scp 1 http://newenglandsubarus.com/ Link to comment Share on other sites More sharing options...
