red beast Posted March 11, 2005 Share Posted March 11, 2005 i bought the 500 degree paint and the 1500 degree paint the 500 goes on WITHOUT HEAT curing. the 1500 degree needs 60 minutes to dry and then must be cured by baking it at 650 degrees for 60 minutes. do you think the mufflers will get hot enough for 60+ minutes of idle? Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 11, 2005 Share Posted March 11, 2005 I doubt it. I think the 500 degree stuff will do the trick. I'm sure the mufflers won't get to 650 degrees. Link to comment Share on other sites More sharing options...
red beast Posted March 12, 2005 Author Share Posted March 12, 2005 I doubt it. I think the 500 degree stuff will do the trick. I'm sure the mufflers won't get to 650 degrees. that's what i thought but i wasn't going to touch it with my tongue to find out. also the 1500 degree paint states that if it's not fully cured it will rub off. Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 12, 2005 Share Posted March 12, 2005 that's what i thought but i wasn't going to touch it with my tongue to find out. also the 1500 degree paint states that if it's not fully cured it will rub off. I remember reading about people painting their mufflers with black engine paint- the same stuff they used to do their headlight mods on the WRX, which was the 500 degree stuff. You should be fine. Link to comment Share on other sites More sharing options...
red beast Posted March 12, 2005 Author Share Posted March 12, 2005 thanks it happening tomorrow morning along with other goodies. Link to comment Share on other sites More sharing options...
