ET3 Posted July 15, 2009 Share Posted July 15, 2009 I just had the rallitek front and AVO 20mm rear swaybar installed recently, and about a week later, the rear started squeaking after it rained. I am searching through the posts, but I thought I read somewhere that others might have had the same issue. They were packed with grease, and rallitek says that they should not make noise, so the rear must have been installed incorrectly. I also installed end links as well. Any ideas, and in the meantime, I'll keep searching. Thanks. Link to comment Share on other sites More sharing options...
Verwilderd Posted July 15, 2009 Share Posted July 15, 2009 Tighten the bolts on the endlinks and see if it goes away. Also make sure there's enough grease on the bushings that wrap around the bar because that can squeak if there wasn't enough grease put on. Link to comment Share on other sites More sharing options...
