Dark-V Posted July 13, 2009 Share Posted July 13, 2009 Okay. You're probably thinking "yeah yeah we've heard this, 20 clicks... BS". Well, I had my seat off, trying to figure out a way to disable the passanger's seatbelt chime. And I have. Some of the suggestions were that inside the seatbelt buckle there is a switch that gets pressed in, and you can clip the wires and connect them, this isn't true. It's NOT a regular push switch. It's a magnetic switch, so connecting the two wires together won't work. *WARNING* You WILL need to take the cover off of the buckle, and pull out the switch (which does involve breaking the switch housing). I couldn't find a way to properly take it out, but since it works, I just broke the switch out. ONCE YOU DO THIS, I CANT SEE HOW IT CAN BE UNDONE! Once you get the buckle cover off, take a look at what happens when you buckle in the seatbelt. There is a metal rod that slides into a groove in the switch (the switch has the two wires coming out of it and is a little white/black plastic box). This triggers the switch and indicates the seatbelt is connected. Now, you can cafefully break out the switch from the housing, and put a piece of ferrous metal into the groove (I clipped a piece of metal from a cheap tool) and tape it together. Hide the switch under the seat (zip ties work, I stuffed it under the left side cloth) and you're done. Like I said before, this is a permanent fix, but I don't want to go back anyway. Sorry, though, I didn't take pictures. Link to comment Share on other sites More sharing options...
doctorbrody Posted August 28, 2009 Share Posted August 28, 2009 I just did this - it's a beautiful thing. Thanks for the info. Link to comment Share on other sites More sharing options...
