dbrunone Posted July 9, 2009 Share Posted July 9, 2009 So here' a 3rd gear pull of my stg2 protuned car. Should I be concerned that there is so much negative knock correction and knock learning, while there is even more positive learned ignition timing??3rd gear pull 1.csv Link to comment Share on other sites More sharing options...
testes1010 Posted July 9, 2009 Share Posted July 9, 2009 IMHO, your going rich too late causing the -KC. The timing curve could be smoothed out as well as the boost curve. Link to comment Share on other sites More sharing options...
dbrunone Posted July 9, 2009 Author Share Posted July 9, 2009 Yeah but it seems like the ECU is adding positive timing (+6deg in some cases), then backing it off for knock (-2.5deg in some cases). Is this a concern? Seems screwed up to me. Link to comment Share on other sites More sharing options...
Spec B Posted July 9, 2009 Share Posted July 9, 2009 There are 2 timing tables a base and an advance. The base is just as you would guess...a base. The advance table adds timing to the base assuming if there is no knock. Positive timing is normal. Link to comment Share on other sites More sharing options...
Ridgeracer Posted July 9, 2009 Share Posted July 9, 2009 Yeah but it seems like the ECU is adding positive timing (+6deg in some cases), then backing it off for knock (-2.5deg in some cases). Is this a concern? Seems screwed up to me. Your right. It is screwed up. You need to have the timing and boost profiles smoothed out. You should not allow the car to constantly correct for bad timing like that. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
weitek Posted July 10, 2009 Share Posted July 10, 2009 Assuming your wide band/logs are accurate, your car is running dangerously lean. I would take it back and request them to look at it and correct the problem. Hopefully you used a reputable tuner and they will stand behind their work. Link to comment Share on other sites More sharing options...
dbrunone Posted July 11, 2009 Author Share Posted July 11, 2009 I did not use a wideband to log it. MSPT tuned it. Link to comment Share on other sites More sharing options...
weitek Posted July 12, 2009 Share Posted July 12, 2009 So where are those logs from? I was under the impression you had logged the car. If those logs are from the tuner that seems really messed up. Either way I would not boost at all until you get it figured out. If those logs are right you are running high 13's AFR at almost 20 PSI. I almost have to believe the logs are wrong since if that were the case your engine probably would have exploded already. At least I hope so for your sake. Eek :\ Link to comment Share on other sites More sharing options...
dbrunone Posted July 12, 2009 Author Share Posted July 12, 2009 Yeah that is weird how it takes so long to bring the AFR back down to 11.1. I gotta talk to Dave. Link to comment Share on other sites More sharing options...
mspt Posted July 13, 2009 Share Posted July 13, 2009 Yeah that is weird how it takes so long to bring the AFR back down to 11.1. I gotta talk to Dave. I can't get a hold of the guy. replied to your email last week,lets reset the ecu and send me the logs-- thanks dave Link to comment Share on other sites More sharing options...
dbrunone Posted July 13, 2009 Author Share Posted July 13, 2009 sorry dave, i didnt get the email. i'll get you some logs within the next day or 2. Link to comment Share on other sites More sharing options...
mspt Posted July 16, 2009 Share Posted July 16, 2009 dave give me a call sent you a email--would like to pressure test intake system dave Link to comment Share on other sites More sharing options...
dbrunone Posted July 21, 2009 Author Share Posted July 21, 2009 If anyone wants to know, Dave is the man. Got everything cleared up, no problem. Link to comment Share on other sites More sharing options...
SkateAndDestroy Posted July 21, 2009 Share Posted July 21, 2009 If anyone wants to know, Dave is the man. Got everything cleared up, no problem. What did it turn out to be? Link to comment Share on other sites More sharing options...
jim1969 Posted July 21, 2009 Share Posted July 21, 2009 glad this worked out. Dave is the man. Link to comment Share on other sites More sharing options...
dbrunone Posted July 21, 2009 Author Share Posted July 21, 2009 Dave pressurized the intake, and found a leak in the IC outlet hose. Some adjusting fixed it. He drove, logged, and adjusted the car for almost 45min after that. I also got to look around their shop for awhile. A lot of great modded Subarus around there. Also, there was one 08 STI in the bay with everything in the engine bay ripped out, and a new crate motor next to it. I wonder why that one blew up... Link to comment Share on other sites More sharing options...
jim1969 Posted July 21, 2009 Share Posted July 21, 2009 great shop. Always something cool going on in there. Link to comment Share on other sites More sharing options...
SkateAndDestroy Posted July 21, 2009 Share Posted July 21, 2009 Dave pressurized the intake, and found a leak in the IC outlet hose. Some adjusting fixed it. He drove, logged, and adjusted the car for almost 45min after that. I also got to look around their shop for awhile. A lot of great modded Subarus around there. Also, there was one 08 STI in the bay with everything in the engine bay ripped out, and a new crate motor next to it. I wonder why that one blew up... Awesome, glad you got it all squared away..is that the hose from the IC to turbo or the IC to throttle body? I have my car tuned by Dave too. Link to comment Share on other sites More sharing options...
dbrunone Posted July 21, 2009 Author Share Posted July 21, 2009 IC to TB. Pain in the butt to get to that clamp. Link to comment Share on other sites More sharing options...
mspt Posted July 22, 2009 Share Posted July 22, 2009 Dave pressurized the intake, and found a leak in the IC outlet hose. Some adjusting fixed it. He drove, logged, and adjusted the car for almost 45min after that. I also got to look around their shop for awhile. A lot of great modded Subarus around there. Also, there was one 08 STI in the bay with everything in the engine bay ripped out, and a new crate motor next to it. I wonder why that one blew up... glad i could help dave,the 08 sti have a piston problem and subaru is replacing complete long blocks now..keep in touch dave Link to comment Share on other sites More sharing options...
