gogordo Posted July 9, 2009 Share Posted July 9, 2009 I'm new to the suspension world and need advice on what I need to replace. Here's the story: I was taking a turn on a wet road and slid sideways into the curb. The passenger front wheel took most of the hit and the passenger real wheel took a small hit. Damage I know of: Wheel is completely shotLCA weld is loose See pics in this post: http://legacygt.com/forums/showthread.php?t=115797 End Links: I was working on removing my LCA when I cam across the sway bar / stabilizer bar end links. They look a bit twisted. See photos. Sway Bar Brackets: I also noticed that the passenger side sway bar bracket looks damaged. See photos. My current plan was to replace the following: LCALCA BushingsBall Joint Should I also replace the end links and sway bar brackets? If the end links are twisted like that, shouldn't I just replace the sway bar too? Link to comment Share on other sites More sharing options...
