cstefanic Posted July 8, 2009 Share Posted July 8, 2009 So, here's a wonderful thing: the LED that is inside my gauge cluster over the 2k-4k RPM sweep area has burnt out. Now I'm stuck with a fantastic looking dark area on my tach. Does anyone know if it's possible to replace that or if I'd be stuck with getting a whole new cluster and having the dealer program it? Link to comment Share on other sites More sharing options...
TNPaparazzi Posted July 17, 2009 Share Posted July 17, 2009 Have you tried lightwerkz.net? I was planning on sending my cluster out for a color change to them one of these days. The page has been redesigned and I cant find the pricing on it but try to contact them Link to comment Share on other sites More sharing options...
cstefanic Posted July 17, 2009 Author Share Posted July 17, 2009 Well, you know what's weird? The stupid thing started working again for a bit the other day, so I'm thinking it's a loose connection somewhere instead. However, it's back out again this morning, so I have no idea what to do exactly. Link to comment Share on other sites More sharing options...
OBieXT Posted July 17, 2009 Share Posted July 17, 2009 Probably a bad solder joint on an LED. If you have a friend with a soldering iron and good abilities, it probably wouldn't be too hard to fix. I wouldn't recommend trying it yourself unless you're pretty experienced with such things. Those circuit traces are TINY. Link to comment Share on other sites More sharing options...
cstefanic Posted July 20, 2009 Author Share Posted July 20, 2009 Okay, I'm thinking this is somehow related to the dimmer "ILL1-6" switch because today it went from off to on and the display showed "ILL6". However, when I'm flipping the switch from 1-6 over and over it doesn't go on or off when it's off or on, respectively. Hmm... Link to comment Share on other sites More sharing options...
