pontiactempest Posted July 8, 2009 Share Posted July 8, 2009 hey, i have a silver 05 lgt limited.today after driving all day i went to go to the store and the CEL came on.thn i checked the gas cap because i got it early and i took it off and clicked it(like usual), i shut it off then turned it back on and it was still on and the cruise light started flashing and wouldnt shut off.i read all the other post about the CEL. the car is completely stock with 35k miles.who has had this fixed and what was the problem.? just a f'd up code or messed up gas cap, modual, o2 sensor, maf sensor? also its slap stick not MT and when i downshift it sounds like the gears are being banged.this normal? i never noticed it before :spin: thanks for any help! Link to comment Share on other sites More sharing options...
AWDxBOOST Posted July 8, 2009 Share Posted July 8, 2009 try unplugging the battery for 5mins to see if it will reset as for the gears, im not really sure what exactly u mean it sounds like...can u video it or something? Link to comment Share on other sites More sharing options...
pontiactempest Posted July 8, 2009 Author Share Posted July 8, 2009 ok ill do that tomorrow. hmm it sounds like its slipping. but its not.get it? i cant get a video.it just sounds like im banging the gears lol.idk... thanks though! Link to comment Share on other sites More sharing options...
MeoW71 Posted July 8, 2009 Share Posted July 8, 2009 You need to get the codes read. Can't do much without that. I know some car parts places (Autozone..) will read your codes for free. With that information you figure out what the problem is without second guessing. Link to comment Share on other sites More sharing options...
Forced air Posted July 8, 2009 Share Posted July 8, 2009 Disconnecting the battery will not clear the codes on an OBDII system. Go down to your local AutoZone or Advance Auto and they can read the code for you. Most common it seems from reading stuff on this forum is the P0011 and the P0012. Cam Position sensor, Timing over advanced bank 1. Dirty oil can also trigger this code. Are you due for an oil change? ...but guessing is not an option. Go get the codes read. They do it for free. If you linger, the next thing to go will be the turbo. I speak from experience, sad to say:redface:. Link to comment Share on other sites More sharing options...
hifonic Posted July 8, 2009 Share Posted July 8, 2009 From what I hear Autozone doesn't read codes anymore bummer. Link to comment Share on other sites More sharing options...
ehsnils Posted July 8, 2009 Share Posted July 8, 2009 Buy a reader (maybe together with some friends if you think it's too expensive). A tactrix cable will be fine too and use some open source software to read codes and sensors. Link to comment Share on other sites More sharing options...
Forced air Posted July 8, 2009 Share Posted July 8, 2009 From what I hear Autozone doesn't read codes anymore bummer. They still do but they are not allowed to clear the codes, some stoopid law, but you can take advantage of their loaner program. You pay for the scanner, do your thing then return it for a full refund. All the stores should have a loaner scanner. Link to comment Share on other sites More sharing options...
ppettit2005 Posted July 8, 2009 Share Posted July 8, 2009 Mine did the same thing before I bought it during the test drive... except for the gear grinding noise thing... Eventually the dealership fixed it before I bought it. They said it was the battery on mine, which makes no sense to me. I don't exactly know what they did, but they did fix it. Your car should still be under warranty at that mileage, so it would probably be a good idea to take it in and have it looked at because you could still get it fixed for free under warranty with them. Link to comment Share on other sites More sharing options...
pontiactempest Posted July 8, 2009 Author Share Posted July 8, 2009 im tacking it to the dealer tomorrow and yea it is under warrenty.so ill see.i kind of dont like autozone or pepboys with the scanning thing.id rather go buy one.but im taking it to the dealer anyway Link to comment Share on other sites More sharing options...
