E-Tank Posted June 30, 2009 Share Posted June 30, 2009 I just went stage 2 and am very happy with the results. I do plan on upgrading to a VF52 when my VF40 bites the dust, although when installing the parts I checked and I could not detect any shaft play whatsoever. The car feels good, but I feel like it could use more fuel. Would it be feasible to install bigger injectors and/or a larger fuel pump with the stock turbo? Also, what should i do from here? My engine mods thus far are only catless up, cattless dp, and AP. I plan on getting a more aggressive stage 2 tune, but I need to finish with all my bolt ons first. Thanks:) Link to comment Share on other sites More sharing options...
Spec B Posted July 2, 2009 Share Posted July 2, 2009 You could max out the stock injectors on really cold days with a FMIC and stock turbo..I have come very close. But you do not need to get injectors and pump. If you swap the injectors you will need a new tune and get very little (if any) performance gain. You could just add the pump..that will not reqire a new tune and it will give you a little more headroom. Link to comment Share on other sites More sharing options...
