dave g Posted June 25, 2009 Share Posted June 25, 2009 When my Sirius was installed in the cubby, the wriing blocked the AC door from working and my AC was not so cold until the wires were re-routed. Now a different shop removed the Sirius and the AC only blows full cold regardless of where I set the knob. What should I look for to cure this? Link to comment Share on other sites More sharing options...
dwolson2 Posted June 25, 2009 Share Posted June 25, 2009 did they go into the ac box? if they didn't check if there is a motor on the blend door and make sure its plugged in. my best guess is that your blend door is all the way open, so you need to figure out why its open and not closing when you put on the heat Link to comment Share on other sites More sharing options...
