Rallitek spring question
firepyro515
Hey guys
Quick question, I will be picking up a set of rallitek springs in the next couple weeks. Rallitek says that they will lower the rear about .9 inches and the front about 1.1 inches. In looking at it, I'm wondering if there will be enough space to lower the back end, it looks like it is gonna be really close.
Wheels - 17x7. 42mm
Tires - 205/50 R17
Any help would be great!
Thanks
  • 2 weeks later...
Well I just put them on tonight, so they may not have completely settled, only put around 40 miles on them. There is around 1.5-2 finger gap in the rear at the moment ... so it should be fine... but you have a 42 offset, which probably puts your wheels at or slightly past the fender right? That means you are more likely to rub when the car is weighed down and you are going around corners.
