illnastyimpreza Posted June 11, 2009 Share Posted June 11, 2009 I pulled the whole brake assembly off a 2001 Outback. It swapped onto my 98 Legacy L great...except on the outback the brake lines come from the BACK of the car!.... not the same as my car. My brake lines come from the top front. And the "Notch" for the brake lines is on the BACK of the car ! YES its installed on the correct side of the car, the bleeder nipples are facing UP. http://i71.photobucket.com/albums/i152/illnastyimpreza/brake.jpg I tightened down the bolt pretty tight. Should this be OK ?? whata u guys think ? I bled the system out perfect and everything. The brakes are fully functional.... The ONLY thing is the brake line is NOT going through that notch. Link to comment Share on other sites More sharing options...
trackhore Posted June 12, 2009 Share Posted June 12, 2009 My rear Brembo calipers are like that, have had no issues for two years. Is that picture of your front caliper? Take into account that caliper is tied to the steering knuckle and moves every time you turn, causing more flex and movement on the brake lines. Not sure I'd be happy with that as the final result on my own personal car. You might have to get creative with some stainless steel aftermarket brake lines that have the proper angled banjo fitting that the caliper requires. Link to comment Share on other sites More sharing options...
illnastyimpreza Posted June 12, 2009 Author Share Posted June 12, 2009 no its the rear H6 upgrade. I learned that all the subaru 4 pots are the same way...they have no notch at all ! I should be good to go ! Link to comment Share on other sites More sharing options...
