SpecBGuy Posted June 2, 2009 Share Posted June 2, 2009 hi new guy. i just got my specb on memorial day. yesterday i was looking at my car and realized that the left side of the car is lower then the right side of the car:confused:. im going to take it to dealer on thursday but need to know what might be the problem.. im all stock except tinted windows. if any 08specB owner have the stock height of the car would be helpful for which i dont know what side is stock height also my stock rims have stains i cant even get out so hopefully warrenty will get me a new set of 4.. thanks Link to comment Share on other sites More sharing options...
SpecBGuy Posted June 3, 2009 Author Share Posted June 3, 2009 nobody know i guess??? Link to comment Share on other sites More sharing options...
AZP Installs Posted June 3, 2009 Share Posted June 3, 2009 Stains? My guess is that it's grease from the hub/bearing. As for the height, never heard of that on a new/stock car. Seems odd. -mike Link to comment Share on other sites More sharing options...
rs6er Posted June 4, 2009 Share Posted June 4, 2009 Are you sure it's lower? It's fairly common for the wheel gap to be greater on one side of the car. Mine is. At a very good alignment shop they told me that the gap is different but the car is level. Link to comment Share on other sites More sharing options...
rtbrjason Posted June 4, 2009 Share Posted June 4, 2009 The staining issues on the 08 wheels has been mentioned here before. Mine may have had some staining at one point, but they're clean now. Have you measured the wheel gap all around? Link to comment Share on other sites More sharing options...
SpecBGuy Posted June 4, 2009 Author Share Posted June 4, 2009 the gap between fender and tire, the right side is 4cm higher in front and 6cm higher in rear. the car seems leveled but the difference is noticeable the stain on the wheels wont even scratch off its like part of the wheel now. taking it to dealer on friday so hoping both problems will be fixed Link to comment Share on other sites More sharing options...
Darkness of Death Posted June 4, 2009 Share Posted June 4, 2009 sometimes it is just where the car is parked, the weight could be more on one side than the other.. i've wondered about that too before - as i had the same concern. Link to comment Share on other sites More sharing options...
grimsleeper Posted June 4, 2009 Share Posted June 4, 2009 the gap between fender and tire, the right side is 4cm higher in front and 6cm higher in rear. the car seems leveled but the difference is noticeable the stain on the wheels wont even scratch off its like part of the wheel now. taking it to dealer on friday so hoping both problems will be fixed Are you sure you don't mean mm? A 2.3/1.6 in. difference between sides is pretty huge. Link to comment Share on other sites More sharing options...
SpecBGuy Posted June 9, 2009 Author Share Posted June 9, 2009 the service guy told me the car needs to settle into place but new car needs to settle? its an 08 how much longer does it need. anyways ill stress about it later when i drop my car in the future. the car drives fine right now. yes i ment mm Link to comment Share on other sites More sharing options...
AZP Installs Posted June 9, 2009 Share Posted June 9, 2009 There shouldn't be any settling on the car unless there are aftermarket springs on it. -mike Link to comment Share on other sites More sharing options...
mercury3545 Posted June 10, 2009 Share Posted June 10, 2009 SpecBGuy Ive noticed the same thing on my Spec B. I took it to the shop and they looked at it and said its fine. I really dont think it is because the height difference is pretty noticeable. Link to comment Share on other sites More sharing options...
SpecBGuy Posted June 12, 2009 Author Share Posted June 12, 2009 i guess some 08 are made this way? the car does drive fine w/o problems. we'll see after i drop my car later on Link to comment Share on other sites More sharing options...
