slushboxgt Posted May 29, 2009 Share Posted May 29, 2009 Hi, I just bought an '08 GT and I want to upgrade the sound system using the stock head unit. I know that there are no line outs on the stock unit, so I'm thinking a five channel amp like a Kicker 08ZX700.5 that has high level inputs? If needed I could later add a clean sweep, but I'd like to keep the factory volume control if possible, and keep the cost down. I will replace the front speakers and keep the rears for fill, I'm thinking something along the lines of Infinity reference 6.5 coax? I would also need some type of sub, but this is a daily driver so I don't want to loose a bunch of trunk space, or the fold down rear seats, ideas? I listen to lots of jazz, rock, alternative, and some classical (sounds like a personals ad ). Not looking for boom boom boom, and don't expect miracles, but a nice tight clean integrated sound with good base response and a modicum of punch for my fading hearing . Thanks, Paul Link to comment Share on other sites More sharing options...
YCAGEL TG Posted May 30, 2009 Share Posted May 30, 2009 You don't need a 5 channel amp to do what you want especially if you are keeping the rear speakers (I would not amplify them). JL makes a nice 10" box with a small foot print. But asking people here what sub they like will return similar results as asking what your favorite ice cream is. (same with the speakers) A good start would be dynamating the crap out of your doors. This made a huge difference in sound even with the stock speakers, not necessarily in the quality or clarity though. Link to comment Share on other sites More sharing options...
darkside Posted May 30, 2009 Share Posted May 30, 2009 Hey, I would recommend a MTX REQ-5, It is a highend Hilow adapter that restores factory bass and has some adjustments.. Also will boost amplifiers signal to 8 volts, making sound clearer.. Only about 79.99.. That what i am using for my sound system setup and sounds great.. the Mtx req-5 will restore good midbass to factory speakers.. I currently have to amps a 4channel for mids and a 1 channel for bass.. I would definately recommend some new front door speakers, like a set of components.. and at least 1 10inch sub for some bass to match music.. Easiest set up would be a 5 channel amp.. keeps it simple.. The Mtx req-5 also has a extra aux you can use. Any question hit me up.. Link to comment Share on other sites More sharing options...
ean611 Posted May 30, 2009 Share Posted May 30, 2009 Also, if you want really good sound, use a Rockford Fosgate 3Sixty.2. 1/3rd octave EQ for all channels, and it will interface with the OEM stereo and work with the amp you have Link to comment Share on other sites More sharing options...
dwolson2 Posted June 26, 2009 Share Posted June 26, 2009 a good first step is replace the deck, I really like bass, but have a wife, and the factory speakers are good enough for me. well not really but enough that I am not complaining like I was before, look on the first page of the interior audio section for the JDM conversion for more info Link to comment Share on other sites More sharing options...
