iahtnoob Posted May 19, 2009 Share Posted May 19, 2009 Changing my own transmission, front diff, and rear diff on an 05 5eat LGT. The front diff drain plug is labeled as "diff oil" and it uses a T70 torx bit. I think i found the transmission drain plug and it uses a 5/16 hex key. I don't know what i need to use for the rear diff? What are the other tool options that could take place of the hex key because i don't know if i can get the leverage with the hex keys. Could someone help. Link to comment Share on other sites More sharing options...
holyjoetart Posted May 20, 2009 Share Posted May 20, 2009 A hex socket and a ratchet. 3/8 drive. You can get at any Sears or parts store Link to comment Share on other sites More sharing options...
meier motor sports Posted May 20, 2009 Share Posted May 20, 2009 my lgt is 1/2 drive fill plug for the rear diff Link to comment Share on other sites More sharing options...
