legacy3076 Posted May 18, 2009 Share Posted May 18, 2009 Im going to obviously install them soon but would like to know if i need to buy the endlinks so it can be dropped correctly. I am not dropping more then .9'' but I still think it may need something like camber kit for it. do I use those camber bolts or is there a kit someone makes? Link to comment Share on other sites More sharing options...
MiniStiGuy Posted May 19, 2009 Share Posted May 19, 2009 I just dropped mine with stock struts and nothing else. OEM HID's Rx330 Retro Link to comment Share on other sites More sharing options...
Impulse Posted May 19, 2009 Share Posted May 19, 2009 same here, works fine. for the front, theres enough adjustment in the stock bolt for it to work. i got everything all zeroed out in the front and it runs fine. i dont think you can/need to adjust camber in the back? just toe. regardless, its fine and within spec. not a big drop, settles down over time to even out. Link to comment Share on other sites More sharing options...
