bnguyenbb6 Posted May 17, 2009 Share Posted May 17, 2009 Hey guys, I just logged some new maps I got from Tuning Alliance. The STU map is a stage 2 map running stock boost so that its within STU rules. Can someone give me feedback? I'm not sure I know what I'm looking at. Please give me your feedback. Thanks, I actually have an AutoX tomorrow . Sorta late to post but give me a break, I had finals this week. Thank you in advance.stu map 1.csvstu map2.csvTA Stage 2 log1.csvTA Stage 2 log2.csv Link to comment Share on other sites More sharing options...
Ridgeracer Posted May 17, 2009 Share Posted May 17, 2009 Well the stu logs 1 & 2 look fine. As for the stage 2 logs, you have a bit of knock correction at timestamp 3624 in log 1 and 3952 in log 2. Just have Mike tweak the timing slope ahead of that knock event. Both logs show that's its occurring right when you come into full boost. BTW...looks like stage 2 log 2 has some shift knock towards the end...timestamp 9545. Could you repeat the log but log knock sum instead of feedback knock correct and fine learning knock correct? "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 17, 2009 Author Share Posted May 17, 2009 Thank you so much! I appreciated it. Thats exactly what I thought I was seeing (STU fine, Stage 2 some knock). What is shift knock? And I'll datalog it again probably Monday or tomorrow after the AutoX. Thanks again. Link to comment Share on other sites More sharing options...
Ridgeracer Posted May 17, 2009 Share Posted May 17, 2009 Shift knock is "knock" that occurs during a gear change. If you log engine load it will give you a better idea of whats going on. Try a 3 to 4th gear pull and log engine load. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
vodoo-chile Posted May 18, 2009 Share Posted May 18, 2009 How was the event or did you get rained out? Curious to see how your logging and tune goes as I might want to get you to help me set up my logging when I get my tune beginning of June. Kyle Link to comment Share on other sites More sharing options...
j255c Posted May 18, 2009 Share Posted May 18, 2009 shift knock is nearly impossible to tune out, dont worry about it. 06 TB EVO IX SE stock turbo monster subaru hater Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted May 18, 2009 Author Share Posted May 18, 2009 I ran on horrible tires during the event but it was great actually. Overcast(67*F) all day untill about 4pm then sun came out and fried every one. My buddy won the novice class in my car(hes had track experience under his belt). I was all nerves all day and on my last run(calmed down a little) I jumped 12 spots to 10th place in the novice class. Not too bad for my 2nd time out there. I'll log the car again later tonight, theres usually too much traffic during the day. Link to comment Share on other sites More sharing options...
