Dusty B Posted May 14, 2009 Share Posted May 14, 2009 So I have an oppurtunity to buy a set of 17x7.5 48ET ASA Ka3 wheels at an awesome price here at work. Wheels are chrome, finish is beat so I was thinking a powercoat job. Wheels would come wrapped in nearly new Bridgestone potenza RE0960's in a 235/45R17. Yes I know this wheel/tire combo is heavy, but I'm mainly looking for experiences with this size tire on a similar sized wheel. Any/all input is greatly appreciated! Link to comment Share on other sites More sharing options...
Dusty B Posted May 14, 2009 Author Share Posted May 14, 2009 Found a little more info as I've been searching around. Still could use some reviews from people running that size though. Link to comment Share on other sites More sharing options...
rnstein69 Posted May 14, 2009 Share Posted May 14, 2009 I have the ASA ka3's for my winter setup. I will give you a head warning though, the holes where the wheel studs go through are very deep, deeper than most other aftermarket wheels. The holes are also very narrow (21.5 mm if I remember correctly) meaning that you have to get tuner lugs. The bigger problem though is the hole depth. I was only able to get about 3.5 or 4 turns of the lug nut on this wheel which is not nearly enough to be safe. I was looking at getting extended wheel studs anyway which I did. The stock wheel stud length is 48 mm and I got nismo 60 mm wheel studs allowing a very safe 18 turns of the lugnut. Stock lugnut on a stock wheel is about 9 turns. If you want to go through the trouble of changing wheel studs then go for it, otherwise I would steer clear of these wheels. It is not worth the risk of having only 3 or 4 threads of the wheel stud catching the lug. Link to comment Share on other sites More sharing options...
whitetiger Posted May 14, 2009 Share Posted May 14, 2009 235/45/17 is a tall tire. if you have stock lgt struts, it may not fit. Link to comment Share on other sites More sharing options...
rnstein69 Posted May 14, 2009 Share Posted May 14, 2009 Here is some more info in a thread that I started: http://legacygt.com/forums/showthread.php?t=108946 Link to comment Share on other sites More sharing options...
Dusty B Posted May 14, 2009 Author Share Posted May 14, 2009 Thanks rnstein69 and whitetiger. I did come accross the thread you mentioned, and read about the extended studs. I would certainly consider buying them if it were a matter of safety. The tire height was the other big concern. I am on stock struts and cobb sport springs... although I know the springs have nothing to do with tire to strut clearance. Link to comment Share on other sites More sharing options...
rnstein69 Posted May 14, 2009 Share Posted May 14, 2009 Thanks rnstein69 and whitetiger. I did come accross the thread you mentioned, and read about the extended studs. I would certainly consider buying them if it were a matter of safety. The tire height was the other big concern. I am on stock struts and cobb sport springs... although I know the springs have nothing to do with tire to strut clearance. not a problem. getting longer wheel studs was worth it for me in the long run since I do auto cross my car 6 to 8 times a season, so changing wheels is a frequent thing for me. Link to comment Share on other sites More sharing options...
Dusty B Posted May 14, 2009 Author Share Posted May 14, 2009 Heh. Even if I don't autocross or anything I wouldn't feel too confident with only 3-4 turns on each stud, haha. Now the main concern would be tire height. From what I remember reading you went with a 225 series tire correct? Link to comment Share on other sites More sharing options...
rnstein69 Posted May 14, 2009 Share Posted May 14, 2009 I used my stock tires on the ASA wheels which are 215, but next set I get I will go with a 225 width. Link to comment Share on other sites More sharing options...
Dusty B Posted May 14, 2009 Author Share Posted May 14, 2009 Do you happen to have a picture of the wheels installed on your leggy? Link to comment Share on other sites More sharing options...
rnstein69 Posted May 14, 2009 Share Posted May 14, 2009 I do, but I can't get to pictures now. I am at work. Link to comment Share on other sites More sharing options...
Dusty B Posted May 15, 2009 Author Share Posted May 15, 2009 C/P'D from Xenonks tire/wheel faq thread: 17 in. rims (for GTs 2005-on): 205/40/17 (only for SUPER FAST acceleration and torque; for autocrossing only, do not use for daily driving) 205/45/17 (only for FAST acceleration and torque; for autocrossing only , do not use for daily driving) 205/50/17 (good for snow rally) 215/45/17 (stock) 225/45/17 (good autocross performance tire size for gearing, more mph per gear) 235/40/17 (good autocross performance tire size for torque, more acceleration) 235/45/17 (tallest tire you could use under the GT due to possible suspension clearance issues, best used with an 8" wide wheel) 245/40/17 (good autocross performance tire size for traction, will need to have a flatter alignment to make use of the grip) 255/40/17 (maximum grip, good for track days, will need a 9" rim to make use of the contact patch and a good alignment as well). Still waiting to see if anyone can confirm that the tire will clear a stock strut. Link to comment Share on other sites More sharing options...
rnstein69 Posted May 15, 2009 Share Posted May 15, 2009 C/P'D from Xenonks tire/wheel faq thread: 17 in. rims (for GTs 2005-on): 205/40/17 (only for SUPER FAST acceleration and torque; for autocrossing only, do not use for daily driving) 205/45/17 (only for FAST acceleration and torque; for autocrossing only , do not use for daily driving) 205/50/17 (good for snow rally) 215/45/17 (stock) 225/45/17 (good autocross performance tire size for gearing, more mph per gear) 235/40/17 (good autocross performance tire size for torque, more acceleration) 235/45/17 (tallest tire you could use under the GT due to possible suspension clearance issues, best used with an 8" wide wheel) 245/40/17 (good autocross performance tire size for traction, will need to have a flatter alignment to make use of the grip) 255/40/17 (maximum grip, good for track days, will need a 9" rim to make use of the contact patch and a good alignment as well). Still waiting to see if anyone can confirm that the tire will clear a stock strut. Well, here is the formula for calculating the overall diameter and from that you can get the circumference: so a stock LGT tire is size 215/45/17 so it is 215 mm wide, 45% of the tread width tall with an inside diameter of 17 inches. 215 x 0.45 = 96.75 x 2 = 193.5 mm so converting to inches that is (193.5/10)/2.54 = 7.62 inches 17" + 7.62" = 24.62" overall diameter for the stock tire. so if we take the size 235/45/17 and apply the same calculation: 235 x 0.45 = 105.75 (105.75/10)/2.54 = 4.16 inches x 2 = 8.33 inches 17" + 8.33" = 25.33" That is a significant difference. 235/40/17 is an oddball size, but lets see.. it would have an overall diameter of 24.40" which is much closer to stock. 225/45/17 is a pretty common size would have an overall diameter of 24.97" which is also pretty close to stock. Link to comment Share on other sites More sharing options...
