brooklyngenius Posted May 11, 2009 Share Posted May 11, 2009 so I have a set of Stechs springs for my 09 and I know from my 05 that the rear sags but I was wondering what size is the optimum saggy spacers for these springs?? I see 1/4, 1/8, and 1/2 inch spacers. I'd like the smallest one necessary to take away the sag. useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
GTTuner Posted May 11, 2009 Share Posted May 11, 2009 What struts are you going to use? If you go STI top hats I'd go with the 1/2 shims. Link to comment Share on other sites More sharing options...
brooklyngenius Posted May 11, 2009 Author Share Posted May 11, 2009 it was just going to be stock struts for now. I have something much nicer planned down the road but I can't ride stock height like this useless signature line where i cant mention my sponsors "First Bagged BL5!" Link to comment Share on other sites More sharing options...
GTTuner Posted May 11, 2009 Share Posted May 11, 2009 I'd go with 1/2 spacers. Link to comment Share on other sites More sharing options...
m sprank Posted May 11, 2009 Share Posted May 11, 2009 Using the Geo metro wheel studs in your rear top hats in place of the stock studs will allow you to use 3/8" spacers and still have approx. the same amount of threads to bolt to as stock. If you use 1/2 spacers and these studs you will only have about 2 threads to bolt to. Stock studs will not work with 1/2 spacers. With 3/8" spacers stock studs give you about 2 threads to use. I am using Swift springs (wagon model on a sedan) with Tokico HTS struts and Spec B top hats. With the 3/8" spacers and 90lbs of stereo equipment in the trunk my car sits level to the eye. Link to comment Share on other sites More sharing options...
