CasopoliS Posted May 10, 2009 Share Posted May 10, 2009 I have noticed that the JDM pinks lower the front a little more than the rear. In fact, the rear does not change that much with the correct set of JDM pinks. As I have also come to notice, the stock front-end on the Spec B sits a little high. I wonder what a Spec B would look like with JDM pinks in the front only? Would that be harmful to do that (stock springs in rear with JDM pinks in front)? It seems like it would level the car out. The front might be a little lower than the rear, but I would rather have it that way than the stock setup (which seems to be the reverse). Thoughts? Link to comment Share on other sites More sharing options...
rtbrjason Posted May 10, 2009 Share Posted May 10, 2009 If they don't change much in the rear, why not just get the full set all around? I can't see any harm in what you're proposing though unless spring rates vary dramatically. Do you have a link to a place to purchase the correct springs? I'm somewhat confused about which "pinks" are needed. I'm not looking to lower ride hide too much myself, but would like to get close to an inch lower all around. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 10, 2009 Author Share Posted May 10, 2009 Well the JDM springs sell in sets of Front and Rear, so there is a cost savings to just doing the front. Link to comment Share on other sites More sharing options...
rtbrjason Posted May 10, 2009 Share Posted May 10, 2009 That's a bit strange. I just measured mine and it's 26.75 front and 26.5-26.75 rear. Perhaps after some miles the front will settle a bit. Link to comment Share on other sites More sharing options...
RJS5689 Posted May 10, 2009 Share Posted May 10, 2009 I don't see a problem, but I'm not sure of the spring rate on stock springs. I think the car would look good with some rake. It's a shame there isn't any from the factory. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 10, 2009 Author Share Posted May 10, 2009 That's a bit strange. I just measured mine and it's 26.75 front and 26.5-26.75 rear. Perhaps after some miles the front will settle a bit. Hopefully. I just cleared 600 miles. so perhaps I am just not patient! Link to comment Share on other sites More sharing options...
Ryandigi Posted May 10, 2009 Share Posted May 10, 2009 rallitek springs actually raised my specB a qaurter to half inch. Looks like I should have went pinks since they were made to go with bilsteins correct? The reason the ralliteks raised (advertised as a .9 inch drop for SpecBs) was due to the different tophats....shrug Link to comment Share on other sites More sharing options...
rtbrjason Posted May 10, 2009 Share Posted May 10, 2009 rallitek springs actually raised my specB a qaurter to half inch. Looks like I should have went pinks since they were made to go with bilsteins correct? The reason the ralliteks raised (advertised as a .9 inch drop for SpecBs) was due to the different tophats....shrug Yikes, it's already a bit too high stock. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 10, 2009 Author Share Posted May 10, 2009 rallitek springs actually raised my specB a qaurter to half inch. Looks like I should have went pinks since they were made to go with bilsteins correct? The reason the ralliteks raised (advertised as a .9 inch drop for SpecBs) was due to the different tophats....shrug Yes apparently the pinks fit right in. Here is zmarko's Spec B on pinks: Front: ST2033021020 Rear: ST2038021000 http://img.photobucket.com/albums/v319/zmarko/Picture002-7.jpg http://img.photobucket.com/albums/v319/zmarko/Picture004-13.jpg http://img.photobucket.com/albums/v319/zmarko/Picture007-7.jpg http://img.photobucket.com/albums/v319/zmarko/Picture009-7.jpg Link to comment Share on other sites More sharing options...
Ryandigi Posted May 11, 2009 Share Posted May 11, 2009 maybe I should just buy a front pair of pinks to help even out my ralliteks. I have heard that ralliteks run a pretty aggressive spring rate like pinks...any thoughts? How much would a pair of just front pinks set me back? Link to comment Share on other sites More sharing options...
BT4 Posted May 11, 2009 Share Posted May 11, 2009 You should talk to the rallitek guys. I am pretty sure they have experience with both of these on their legacy gt and can probably give you a real clear comparison. I am pretty sure you will gain some harshness with the pinks. Link to comment Share on other sites More sharing options...
Deadzep Posted May 15, 2009 Share Posted May 15, 2009 I put ST2033021010s on the front and 21000s on the back. The front dropped just a bit over an inch and the back is 3/4 inch lower. Link to comment Share on other sites More sharing options...
CasopoliS Posted May 16, 2009 Author Share Posted May 16, 2009 Just found this post with fronts only: http://www.legacygt.com/forums/showpost.php?p=2388834&postcount=111 Perfect IMO. Once those fronts settle more (looks like he took the pics right after install), it would look great. Link to comment Share on other sites More sharing options...
kirbwrx Posted May 24, 2009 Share Posted May 24, 2009 i want pinks but cannot bring myself to drop $500ish on some springs. prolly go with the ralliteks or swifts when i decide to do springs. Link to comment Share on other sites More sharing options...
rs6er Posted May 24, 2009 Share Posted May 24, 2009 I have a set of Ion fronts for sale. PM me if you're interested. I have pics of the car with them mounted. Link to comment Share on other sites More sharing options...
