sschmelcke Posted May 1, 2009 Share Posted May 1, 2009 i just got my avo adjustable endlinks. whats the best way to adjust these? load or no load. also whats the advantage of making them longer or shorter? thanks Link to comment Share on other sites More sharing options...
sschmelcke Posted May 1, 2009 Author Share Posted May 1, 2009 also the car is at stock height if that makes a difference. Link to comment Share on other sites More sharing options...
Dark-V Posted May 2, 2009 Share Posted May 2, 2009 I just adjusted them to be the exact same height as the stock ones. I pulled off the stock one, compared to the AVO, adjusted. That should be all you need since you're not lowered or changing the swaybar mounting location. Link to comment Share on other sites More sharing options...
sschmelcke Posted May 2, 2009 Author Share Posted May 2, 2009 thats what i figured but i just wanted to make sure. last thing i need is something else breaking on this car Link to comment Share on other sites More sharing options...
