kred Posted January 28, 2013 Share Posted January 28, 2013 Is anyone familiar with the schematics of the turn signal wires? I'm pretty sure that of the two wires at the end of the LGT mirror harness, one is for the signal and the other is a ground wire. Can anyone confirm this? More importantly, if the turn signal mirrors are plug and play with the whole door harness, that means that there must be some wiring for the turn signals at the base of the harness. I just got the mirror harnesses, so I don't know what two do with the two extra wires for the turn signal. There must be an easy way to wire this, but I can't figure it out. I'm so frustrated and confused. Can anyone tell me where these wires should lead to? Link to comment Share on other sites More sharing options...
poorboy006 Posted January 28, 2013 Share Posted January 28, 2013 I would seriously think about just purchasing the harnesses. If you ask around enough you can get them fairly cheap ( I paid $50 for both). Rewiring a harness seems like an uphill battle. Link to comment Share on other sites More sharing options...
kred Posted January 31, 2013 Share Posted January 31, 2013 Even with my GT door harnesses, I'm getting a really weak, barely noticeable flashing on the driver's side mirror. Any ideas? Link to comment Share on other sites More sharing options...
poorboy006 Posted February 5, 2013 Share Posted February 5, 2013 My guess is a bad connection somewhere. Check that the harnesses are plugged tight or for any corrosion on the pins. Dielectric grease may help too. Wish I had a better answer for you. Link to comment Share on other sites More sharing options...
kred Posted February 5, 2013 Share Posted February 5, 2013 My guess is a bad connection somewhere. Check that the harnesses are plugged tight or for any corrosion on the pins. Dielectric grease may help too. Wish I had a better answer for you. You're probably right because my brother said the same thing. I guess I'll try using some dielectric grease on the door harness and see if that helps. I'm also gonna do a voltage test on the turn signal wire. Do you know by any chance what the voltage should be? Link to comment Share on other sites More sharing options...
poorboy006 Posted February 5, 2013 Share Posted February 5, 2013 Off hand I do not, but you could just compare left and right sides and go from there. Link to comment Share on other sites More sharing options...
Dam itz Lou Posted October 12, 2013 Share Posted October 12, 2013 ……….. Link to comment Share on other sites More sharing options...
Dam itz Lou Posted November 30, 2013 Share Posted November 30, 2013 I'm going to buy the mirrors from someone on this board, i'm just wondering if I need the car side connector ? He's including all the other wires. I have a 08 LTD. Link to comment Share on other sites More sharing options...
