shwaldo Posted April 28, 2009 Share Posted April 28, 2009 I've had my 2005 Legacy Sedan for about 4 months. I bought it used, 42K miles. This weird thing keeps hapening with the stereo. I've got a stock single CD player. If I'm listening to the radio, but there's a CD in the player, sometimes it will start playing the CD on its' own. This usually happens when I make a sharp turn. I then have to push the "FM" button to get back to radio. Could there just be something wrong with the button itself, like over-use, or could this be a wiring issue? I'm not sure how to handle. Any suggestions? Thanks. Link to comment Share on other sites More sharing options...
SVXdc Posted May 1, 2009 Share Posted May 1, 2009 Does your car have the audio buttons on the steering wheel? Could be the button there, or the "clockspring" wiring in the steering wheel. You could unplug that 8-pin connector from the rear of the radio and see if the problem goes away. Link to comment Share on other sites More sharing options...
shwaldo Posted May 1, 2009 Author Share Posted May 1, 2009 Does your car have the audio buttons on the steering wheel? Could be the button there, or the "clockspring" wiring in the steering wheel. You could unplug that 8-pin connector from the rear of the radio and see if the problem goes away. No buttons on the wheel. Thanks though. Link to comment Share on other sites More sharing options...
mustangendsley Posted May 1, 2009 Share Posted May 1, 2009 Ya I have a 05 gt, but my problem was on long trips the radio would turn itself down and the radio lights would flicker every 1-2 min. It drives me nuts. and I'm not going under the dash to find any loose wires. Link to comment Share on other sites More sharing options...
SVXdc Posted May 1, 2009 Share Posted May 1, 2009 Both of you guys' symptoms sound like problems inside the radios. There's a small chance that there's something like a loose piece of solder bouncing around on the display board (the PC board that has the buttons and displays), or a dirty connection between that board and the main logic board. If it were happening to me, I'd open up my radio and clean off the contacts on the interconnects and buttons. There are several threads here where people separated the A/C controls with lots of good pictures showing how to do that. But the problem could just as easily be a flaky main logic board. You could buy the same radio from someone whose CD mechanism failed and swap boards. Your only other choice would be to get another whole radio. Link to comment Share on other sites More sharing options...
desertfoxaz Posted May 3, 2009 Share Posted May 3, 2009 I think it's time to perform an exorcism. My car's radio turned itself up to 35 a few weeks ago and I couldn't lower the volume. I had to turn the car off and on again and then I was able to turn it down. Who knows what caused that. Link to comment Share on other sites More sharing options...
