Long Island Legacy Posted April 27, 2009 Share Posted April 27, 2009 Ok i was under the car today and noticed a hydraulic oil leak around the end of the tranny, which i think is the center diff. Does anyone know the cause of this? Link to comment Share on other sites More sharing options...
subarupartsdude Posted April 29, 2009 Share Posted April 29, 2009 Wonder if it's just the rear oil seal where the prop shaft goes..........? Link to comment Share on other sites More sharing options...
Long Island Legacy Posted April 29, 2009 Author Share Posted April 29, 2009 could be thing was covered in grime Link to comment Share on other sites More sharing options...
shaneomac1602 Posted April 29, 2009 Share Posted April 29, 2009 I would like to know also, mine is the same way Link to comment Share on other sites More sharing options...
Long Island Legacy Posted April 30, 2009 Author Share Posted April 30, 2009 i think there are vents on the top the leak could be there, bump for a solid answer to this! Link to comment Share on other sites More sharing options...
TRSCobra Posted May 2, 2009 Share Posted May 2, 2009 First, you should make sure the trans isn't low on oil, then spray the whole thing with brake cleaner and clean it off. Drive it for a day and check again. That should help you pinpoint where the oil is leaking from. Link to comment Share on other sites More sharing options...
