pansontw Posted April 27, 2009 Share Posted April 27, 2009 After doing a lot of researching and reading about spring and strut combination. I figured that ION is a pretty good spring considered it has specific design rate throught out all the model in our legacy. At the mean time, Bilstein HD is one of the most acceptable mild suspension upgrade options we've got. The original idea is good springs + good struts = excellent suspension setup so I put Bilstein HD and ION 2.5i wagon spring together. (w/ HD spring setup at rear) Considering the road condition in Houston is no better than that in California, I am expecting the ride to be better handling but no harshness. Also, I did trim the bump stop for both front and rear in order to get an even more comfortable ride. However, the ride is really really harsh. I 've got a lot of bouncy move for street driving at only 35mph. Sometimes, I feel that the struts are not dampening to absorb the bump from running over pot holes and man holes. I even think the suspension on my friend's mazda 3 is firmer and better than my current setup. My fiancee is complaining a lot and now I am really upset as well. So, guys please help me here on these questions.... Can I adjust Bilstein HD to softer and better dampening??? Will the ride be more comfortable if I reuse my stock wagon springs on Bilstein HD??? Or could the harshness is resulted from the following causes??? 1. Installation problem?? 2. spring and stut combination is not right??? 3. the Bilstein HD strust I got are defective ones??? 4. .....?????? Link to comment Share on other sites More sharing options...
NSFW Posted April 27, 2009 Share Posted April 27, 2009 "Bouncy" sounds like the springs are too stiff for the dampers. Link to comment Share on other sites More sharing options...
pansontw Posted April 27, 2009 Author Share Posted April 27, 2009 This thing just came up on my mind. Is the nut at the bottom of Bilstein HD strut for dampening adjustment?? Link to comment Share on other sites More sharing options...
goneskiian Posted April 27, 2009 Share Posted April 27, 2009 Bilstein HD's aren't adjustable in any way. Link to comment Share on other sites More sharing options...
