Threelions23 Posted April 22, 2009 Share Posted April 22, 2009 I am trying to buy top hats for my tein basics (its clunking when i turn the wheel), i cannot seem to find any info on this... are they camber plates? does camber plates replace the top hats? I'm lost i want to autox my car and i have 25mm sways front and rear aswell, any info much appreciated! Link to comment Share on other sites More sharing options...
katalyst Posted April 22, 2009 Share Posted April 22, 2009 tein basics work with the stock tophats? you could re-order them from subaru. i guess you could use camber plates? i do'n tknow if the GTworx ones from racecomp will work, but NVH will probably be worse with camber plates vs rubber tophats Link to comment Share on other sites More sharing options...
Threelions23 Posted April 24, 2009 Author Share Posted April 24, 2009 Yep the basics uses the top hats, i might just re-order some new top hats from the dealer, the camber plates i heard are very unforgiving... Its too bad there isnt a good set of top hats out there. Link to comment Share on other sites More sharing options...
