braxber Posted April 18, 2009 Share Posted April 18, 2009 im pretty sure i just bought the wrong dp because it said for 08+ wrx/sti since cobb had the same part number for thier downpipe i assummed it would be the same for invidia. the divorced waste gate is keeping the downpipe from seating propperly. there is a 1/2 inch gap between the turbo and the down pipe. are divorced waste gate downpipes hard as hell to install or is it pretty obvious that i bought the wront fittment Link to comment Share on other sites More sharing options...
Ridgeracer Posted April 18, 2009 Share Posted April 18, 2009 The Invidia DP has a divider inside of the bellmouth. I won't work on some turbos. Best if you get the right one for a LGT. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
petefrommeat Posted April 18, 2009 Share Posted April 18, 2009 i had the same problem. heres what you need man http://www.legacygt.com/forums/showt...=invidia+noise its a PITA to take back off and do all this, but everything works out fine. Link to comment Share on other sites More sharing options...
braxber Posted April 18, 2009 Author Share Posted April 18, 2009 thanks man, i ended up grinding the whole tab down about a half inch and then notching it for the waste gate arm. works and sounds like a charm. almost the best $175 ive spent on my car. no to sell me cobb catted downpipe. Link to comment Share on other sites More sharing options...
