Flooded engine?
Putting my car back together tonight (oil seals, water pump, oil pump seals). I ask the dealer how to prime the oil pump and they say it's self priming. I'm not very trustin g of comments like that so I go the extra mile, unplug the coil and crank it for 30 seconds. I plug the coil back in and now it won't start. The garage stinks of raw gas which I take as a sure sign the engine is flooded. When I crank it the engine will fire one every few seconds but it never quite catches. I had this problem a few years ago where I lost one cylinder on a cold start and didn't get it back for about a mile of driving. Any suggestions?
Cranked and cranked and cranked but I could only get to cough before the battery gave out. I gave up for the night and put the battery on my charger. I did see in the manual I should floor the pedal if it's flooded. Too bad I didn't see that before I cranked it. I only wish this were a snowmobile. A set of fresh plugs and a little cranking goes a long way.
