TMIC Upgrade
dx32v
It won't serve any purpose at Stage I. At Stage II, you risk blowing the plastic/metal connection on the Stock IC. So if you're planning to go to Stage II, makes sense to get the AVO or Perrin. I have the AVO and it was an easy fit and got a free tune for it from rallitek. Been pleased so far w/ the AVO. Only took some mild modification to get the engine cover to fit..
An IC upgrade in beneficial at anytime IMO. If your staying with a top mount I owuld suggest the AVO purely on fitment. I have installed both and the Perrin is a tight fit.
Go stage 2 before you upgrade would be my advice.
Why wouldn't a AVO TMIC be worth it at Stage 1? Why do you guys prefer stage 2? What is considered Stage 2? I have seen a number of vendor sites suggesting their own Stage 2, so I am a bit confused. :(
http://www.legacygt.com/forums/showthread.php?t=67940
http://www.legacygt.com/forums/showthread.php?t=48123
