Deunan Posted April 12, 2009 Share Posted April 12, 2009 Hi, just wondering If I can put Bilstein HD and spec-B top hat for the front and Bilstein HD in the rear, with out the drop??? I like my stock height since I put around 38,000 miles a year Any other parts I need? Thanks. Link to comment Share on other sites More sharing options...
rexster Posted April 13, 2009 Share Posted April 13, 2009 no. the OBXT has a longer shock body than the GT. the springs won't work and you will need to use GT springs and lower the car to GT ride height. and since you have taller tires they will hit the upper spring perch once you lower it. if you search for "outback shocks" you'll find a bunch of info... Link to comment Share on other sites More sharing options...
