madcatz Posted April 9, 2009 Share Posted April 9, 2009 aaaaand **** my life All Aspects did a great job, but my car is still fubared..... Mods: 40BB Turbo (suspected to be on its way out) Catless Up/Down Stock Exhaust (ish) Stock Intake Turbo XS Utec DW650 Injectors Perrin TMIC and Go Fast Bits BOV (50/50 Recirc) Max power 217.42 Max Torque 235.03 http://i22.photobucket.com/albums/b309/madcatz1417/dyno.jpg sorry for the shitty pic of the dyno. Kenian says it is either the turbo (most likely) or a boost leak in the TMIC who knows, guess this pushes the 16G turbo install forward with the FMIC then..... -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
Spec B Posted April 9, 2009 Share Posted April 9, 2009 How much boost are you running? That is real low on a dynojet. Link to comment Share on other sites More sharing options...
madcatz Posted April 9, 2009 Author Share Posted April 9, 2009 14.59 lbs.....but we both think that either the turbo is on its way out, or there is a boost leak in the TMIC im pulling the TMIC and redoing the gaskets this next week to see if it will help, but Im not going to do anything but baby it till my parts come in. time to get that second job -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
Spec B Posted April 9, 2009 Share Posted April 9, 2009 i never heard of a 16G turbo for our cars...just 18 and 20. If you are running the stock TMIC check to see if it is coming apart at the tabs. Good luck. Link to comment Share on other sites More sharing options...
madcatz Posted April 9, 2009 Author Share Posted April 9, 2009 Perrin TMIC and Go Fast Bits BOV (50/50 Recirc) Blouch Big Evo III 16G turbo is the turbo lined up to go in http://www.blouchturbo.com/turbos/WRX_TD05H-EVO_III_Big_16G-7CM2/ -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
Spec B Posted April 9, 2009 Share Posted April 9, 2009 Ohh..nice! It is STi fitment..sweet. Link to comment Share on other sites More sharing options...
