tahoegt Posted March 27, 2009 Share Posted March 27, 2009 Going to put Ion springs on a new set of struts. Are there any other parts I need to or should replace while doing the install? I do have a new "creak" in the front when going oner speed bumps. Also, if anyone else has this set up let me know what you think. Thanks Link to comment Share on other sites More sharing options...
Daedalus Posted March 27, 2009 Share Posted March 27, 2009 Are moving to a different strut? Like from the USDM KYBs to JDM Bilsteins? If so, you'll need new front tophats. Do you have any other suspension mods (like swaybars)? That could be the source of the creaking (could also be your current tophats). Some other tips. Use airtools where possible. The rear bolts for the shock are a PITA and will probably require a breaker bar. You'll also want a jack to help you install the rear assemblies. Don't go yanking on the front hubs (rotors) to assist in getting the shock off the hub because you might just accidently pull your axel out of your front diff. Link to comment Share on other sites More sharing options...
tahoegt Posted March 27, 2009 Author Share Posted March 27, 2009 I'm going to have it professionally done. Going with OEM struts. I hear that they are the best pair for the springs. Link to comment Share on other sites More sharing options...
goneskiian Posted March 27, 2009 Share Posted March 27, 2009 I'm going to have it professionally done. Going with OEM struts. I hear that they are the best pair for the springs. Really? I've always been led to believe the OEM struts are overpowered by the OEM springs. Now you're adding stiffer springs? I would think some upgraded struts like Bilsteins or Koni's are in order. I don't know anything more than I've read here though so I'm far from an expert in these things. Cheers! Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 27, 2009 Share Posted March 27, 2009 I think the ions aren't too bad on stock struts though, more aggressive springs tear em up tho Link to comment Share on other sites More sharing options...
tahoegt Posted March 28, 2009 Author Share Posted March 28, 2009 We have really awful roads here and someone told me that the ions with konis are really stiff. That's why I'm sticking with stockers, unless someone has a better idea. Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 28, 2009 Share Posted March 28, 2009 I have the koni's and yes the ride is stiff, but it is not unbearable (and I have horrible roads by me too)....I would say to go aftermarket if you have the money, you will be happier in the long run Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 28, 2009 Share Posted March 28, 2009 Plus they have the adjustment feature (from soft to firm) Link to comment Share on other sites More sharing options...
tahoegt Posted March 28, 2009 Author Share Posted March 28, 2009 Cool. Thanks for the advice. How stiff are you running yours? Do you have aftermarket springs? Only the fronts are adjustable right? Link to comment Share on other sites More sharing options...
goneskiian Posted March 28, 2009 Share Posted March 28, 2009 You could also skip the springs and just upgrade the struts. Have you read the Koni thread where the guy that helped get them developed for the Leggy said just upgrading the struts was a pretty fantastic improvement over stock? Check it out: http://legacygt.com/forums/showthread.php?t=35073 The very post even: http://legacygt.com/forums/showpost.php?p=703671&postcount=103 I would think on rough roads and the snow you drive in you'd want to keep as much ride height as possible. Cheers! Link to comment Share on other sites More sharing options...
Regal05LGT Posted March 28, 2009 Share Posted March 28, 2009 Cool. Thanks for the advice. How stiff are you running yours? Do you have aftermarket springs? Only the fronts are adjustable right? Pretty much right in the middle for stiffness...and I have swifts for springs Link to comment Share on other sites More sharing options...
sicklyscott Posted March 28, 2009 Share Posted March 28, 2009 I just put konis in with the ion springs. I'm running the front and rear stiffness at 3/4 turn from soft, they feel great! The front felt like it was slightly over dampened so I put a little turn to soft on them. It's definatly not a harsh ride. With the konis you won't need top hats. Both front and rear are adjustable. Link to comment Share on other sites More sharing options...
tahoegt Posted April 2, 2009 Author Share Posted April 2, 2009 Yeah, thought about just putting on the Koni's, but I already own the iONs and I think I want the car lowered a little. Link to comment Share on other sites More sharing options...
