MrGlass Posted March 27, 2009 Share Posted March 27, 2009 I'm wanting to get my wife's 05 lgt AP Stage I protuned in a couple of weeks. OTher than the AP, the vehicle is completely stock. Where would you place the wideband?? Thx!! -T Link to comment Share on other sites More sharing options...
Ridgeracer Posted March 27, 2009 Share Posted March 27, 2009 If you are getting a ProTune the tuner should have a WB for the tailpipe. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
MrGlass Posted March 27, 2009 Author Share Posted March 27, 2009 If you are getting a ProTune the tuner should have a WB for the tailpipe. That's what I was thinking but he said the readings would not be as accurate. I didn't know how much of a "concern" that would be since it's only stage I. Link to comment Share on other sites More sharing options...
qikslvr Posted March 28, 2009 Share Posted March 28, 2009 You would need to get a WBO2 bung and have it welded in. Look at post #90 in this thread "what's your wideband solution?": http://www.legacygt.com/forums/showthread.php?t=92446&page=2 You can have one welded into your stock DP for about $20 at any muffler shop. However, a wideband AFR sensor in the tailpipe is pretty much standard operating procedure for most tuners. He probably just wants to see what the AFR is BEFORE the cats. Let's kick this pig! Link to comment Share on other sites More sharing options...
MrGlass Posted March 28, 2009 Author Share Posted March 28, 2009 You would need to get a WBO2 bung and have it welded in. Look at post #90 in this thread "what's your wideband solution?": http://www.legacygt.com/forums/showthread.php?t=92446&page=2 You can have one welded into your stock DP for about $20 at any muffler shop. However, a wideband AFR sensor in the tailpipe is pretty much standard operating procedure for most tuners. He probably just wants to see what the AFR is BEFORE the cats. Thx Link to comment Share on other sites More sharing options...
